1024x768
Normal
0
When A REAR PROJECTION TV has coloured outlines or a 3D
image the Convergence Circuits most likely need attention.
Replacing the output amplifiers (located within the Convergence
IC's) allows the pictures to line up correctly, and no more color
outlines.
This is the most common fault in all makes of rear projection TVs.
Some models of TV require major disassembly and considerable
shop/manufacturer's support to repair because of their design that causes other
power supply or vertical deflection problems. The poorly designed products
require a "bench" repair that can typically cost from $350 t0 $700.
Some TVs are designed for on-site repair and have more reliable circuit design
that does not usually cause damage to other parts of the TV when convergence
chips fail. The ones that usually allow reliable on-site repair are JVC,
Samsung and Hitachi.
It is normal to have some resistors in the circuit burn up or increase in value
from the heat (from 2.2 ohms to 5 or 10 ohms). These resistors must be replaced
with the right value or the chip may fail again.
This is not a simple repair like changing batteries or a fuse. Reading
through the other posts shows many that try and end up with bigger problems.
Your JVC uses STK 392-110 IC's. Misinformed people replace the IC's with
other "new and improved" IC's, like STK 392-150. These are
devices with different characteristics and require different value resistors in
the circuit.Replacing with the STK
392-150 will cause overheating of the resistors and a damaged IC.
If you are in Calgary, I can help. If not, get someone that has experience
working on your JVC. My website is below with some costs and explanation.
The tv Magic Focus button don't solved these R,G,B colors lines mis alignments problems.Mean ur tv have a convergence pictures problems,it is dead.Ur tv now have any colors lines like R,G,B mis alignments,have a colors shadows picture or a 3D pictures look alike?Yes,mean ur tv convergence board it is dead to causes all of these pictures problems.The tv convergence board must have to repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
I was searching online about what could be the problem with our TV and I came across your page. We have a 52" JVC Projection TV that now has a "blurred" screen. We can see the channels but it looks like it's has a shadow around the images. The screen in in a red hue with green blur.
If you have any suggestions on what caused this and what we can do to have this fixed, I would greatly appreciate your advice.
Yes the red tube is shorted. I will post a link to the site where I work as they have an entire AV48WP30 with a bad tuner they are selling parts off of including the Tubes. they also provide free info on how to switch out the tubes as a unit which is a fairly easy job. Heres the link.
You may have a convergence problem that means, there may be convergence ic's bad or related components. If you know something about tv's, try checking things out. You can get a repair manual from websites to download. If you do not normally fix tv's the best thing is to call a tv repair technician.
Perfect! That is typically called "Ghosting" where there is a faint image shadow behind the image on your screen.
I'm glad you were able to get it fixed!
The lightning probably zapped the tuner in you set. If no signal is present the screen is muted (BLUE).This is a feature to prevent your seeing snow on the screen.
Stargazer
