Its ******
Nearly impossible to 'overcharge' the battery on a S032 unless you're using improper equipment. There is a PCB on-board (hard wired into the battery) AND one in the Syma charger that should have come with the helicopter. Undercharging and over-discharging are the biggest threats to Li/Po lifespan. Charge until light is fully on... look at the charger when you unplug chopper, if the light gets brighter when you unplug it, it's not fully charged. And even more important, especially when the battery is new, is to never fully drain it. As soon as you have to give full rotor power to maintain altitude, you should land and power off. Let battery cool for 10 minutes after flying AND 10 minutes after charging. Batteries are cheap (amazon has them for about 5$) and easily replaceable with no soldering and just a small screwdriver.
Are you sure the battery is fully charged the light on the charger
should shine brightly but you might of overcharged it if you have had it on for 90 mins
it is fcked :(
