it must be overflowing.Its not leake. check that if you totally turn the machine off for 2 days .The water still leaks. If yes then replace the water inlet solenoid. if not then check float sensor that its working properly. Thanks Please rate my work
There is a seal kit that is successful about 90-95 percent of the time in fixing the leaking issue. If you will call customer service at 800-352-2866 with your name and address, we will be able to send you a kit to resolve your issue.
If the circuit resets with the coffee maker unplugged, the coffee maker is at fault. There is a defective part in the unit that is shorted causing an overload in the circuit. You will have to isolate the bad circuit and replace or replace the coffee maker.
there's probably a 'silicon rubber' hose that feeds hot water to the 'grounds basket'- it may be loose, or damaged. is it leaking water, or coffee?? we have a bunn 8-cup, which has a pre-heated water tank that brews a pot in about 3 min. energy waster, but when you need coffee, you need coffee!!! is your filter holder properly centered? is the carafe lid hole clean and un-obstructed? if it's leaking water, and not too costly to replace- you may consider replacing it with a new one! good luck!
Are you rapid firing your coffee maker?Not designed to do that.. If the water heated that fast it would boil dry if you ever left it unattended and on. The reservoir is heated with the time it takes to drink a full pot taken into consideration for reheating.. If you are serving 20 cups with a 10 cup machine, Expect a delay, especially if you are refilling with cold tap water. Sorry.
