Mlatham990,
First I would make sure that you have not run out of one color of ink, which will make the colors look funny. This is the most likely problem and can be solved by replacing the cartridge. If you print a test page it should be obvious if a color is missing.
If you are absolutely sure that there is not a color missing then the following information may be helpful.
There is no adjustment for the relationship of the colors at the printer. Depending on the monitor you have you may be able to go into the menu and adjust the tint, which is the relationship of the three colors, but generally monitors use an RGB signal and you cannot adjust the relationship.
If you can adjust the color tint I would print out a test page, or something with the color which is wrong, and then compare the colors on the page to the color on the screen while adjusting the tint to make the two match.
Thanks for using FixYa and for the great rating.
hardrocko
