Your new Garrison Digital Deadbolt comes with a default User Code-1234. As you know, a User Code is used to unlock the deadbolt via the keypad. However, you need to delete the default User Code and then add new ones-for security reasons
are you going to change your lock or security code?if you wish to changer it,or are you trying to put a security on your phone.(* the default code is 12345)
just go to settings > security > lock code and enter your code (there's an option if you wish to change or edit your code.
ur defalt phone code is 12345 or 00000 or 0000 u can use it You may try default phone and security code to remove restrictions. Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
First type *#06# in your mobile and get IMEI number for your mobile
Here are instructions for unlocking a LG VX9200. Before you start make sure that you have a non accepted sim card. 1. First you need to start up your LG VX9200 with a sim card from a non accepted network. 2. Your phone will display “phone restricted” select cancel. 3. Your phone will now display “phone restriction code”. Enter your unique unlock code. Select “OK”. 4. Your phone is now unlocked. As long as you enter the correct unlock code your LG VX9200 will be unlocked allowing you to use it with any sim card. If you don’t have the unlock code search the web for websites that sell unlock codes. Entering the wrong unlock code too many times could permanently lock your phone
OR: call to your customer care they ll provide you the code to unlock
SECURITY CODE from page 54 of your manual: Your phone prompts you for a five-digit security code for certain features and commands. Access is granted only after the correct security code has been entered successfully. The default security code is 12345. It is recommended that you change this code at once, write it down, and store it in a safe place away from your phone. Important: When entering your security code, ***** is displayed on the screen to keep others from viewing your code. You can delete the last entered digit by pressing Clear (or by pressing and holding Clear to delete all the digits more quickly). Enter the correct code or press Back to exit. If you enter an incorrect security code (Code error will appear) five times in a row, your phone won’t accept any entries for the next five minutes. Change your security code 1 Press Menu 4-5-2-4 (Settings > Security settings > Access codes > Change security code) and press Select. 2 Enter existing (or default) security code and press OK. Security and System settings 3 Enter new five-digit security code and press OK. 4 Re-enter your new five-digit security code for verification, then press OK. Your phone displays the confirmation message Security code changed. Important: If you change your security code and don’t remember the new code, contact your service provider. Once you change your security code, the default code is no longer valid.
Hope this helps, let me know if I can help you with anything else. It would be very kind of you if this does work for you to please rate me or leave a short note. I would really appreciate it. Thank you for your time. JimmyC
hello 1_ can you save your formation in other phone . 2_that code format your phone for Nokia only 3_ *#7780# if you know your security numbers use it. if you don’t know it use 12345 4_ other numbers *#7370# and the security n ...... and look if the problem is solve it because after this . you have like a new mobile
The default security code for Nokia is 12345 IMEI: 357968007960658 Master code: 7176552371 Close all applications on your phone. With your phone switched ON, remove the battery. Then remove the SIM card. Replace the battery without the SIM card and switch your phone on. Type in the security codes (any code) until the phone request the Master code, (in the phone lock window) when it does, leave your phone still, don’t use it for 15 minutes, then type in the Master code. This is the code needed to reset the Security code, nothing else, and it’s for your phone only. If it does not request the Master code, your phone will have to be connected to a computer and an unlock box to restore the Security code.
Phone Security Code: This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code: Master Reset Code
Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times.
