Hello
Run a couple of system self test on the refrigerator to see where the problem has occured
Inspect your condenser fan and get a multitester to test the thermistors if they are still in perfect order,if they do not give accurate readings you should replace the condenser fan and thermistors.
Also check out the fresh food evaporator fan if it has not been iced up as this can restrict air flow and make your refrigerator not to cool
The evaporator fan is behind all the plastic back wall and insulation.replace the fan and the thermistor near the top light and clean out all the ice.
Your refrigerator should now work normally.
SOURCE: The temperature display keeps on flashing and will
Either the fridge's controller is trying to indicate a failure, or a temporary power failure has reset the fridge and it's demo mode. Demo mode is the mode used in stores where the lights and stuff will work but the motor doesn't run. Exiting demo mode may be as simple as unplugging it again for a few minutes, but you should look in the troubleshooting section of your manual to find out for you specific model.
