On this website you will find a video to fix this problem e019 canon ir 2200
You need one + screwdriver and a good will :-)
These error means : WASTE TONER FULL.
To get rid of it do next:
On the left sideway of the copier, in lower left corner, there is one plastic cover with one screw. Unscrew it and remove cover. Now You are able to see plastic box/ container with handle. Pull it out.
Empty the waste toner out and clean the box with water or alcohol and dry it.
Especially "take care" around the neck of the bottle, two small holes, because the waste toner full detection is carry out on state if the sensor can see trough or if the sensor cant see trough( E019 ).
If you have some antistatic spray or detergent you should apply it on the neck and dry it so that the toner would not stick to it.
After you putt all in the first state turn off and back on.
Hope that helps.
Sir i have recently purchased IR 400 canon photcopier my problem is the machine is giving error 604as soon the machine is started problem . plz solve my problem
