Palm Treo 750 Smartphone Logo
A
Anonymous Posted on Dec 26, 2010
My screen freezes on windows mobile - Palm Treo 750 Smartphone
BenjamineDupont
Level 3:
Master:
  • Palm Master 465 Answers
  • Posted on Jan 24, 2017
BenjamineDupont
Palm Master
Level 3:
Master:
Answers
465
Questions
0
Helped
206164
Points
2730
You can have a try with LEO Privacy, this is the best app to use to boost phone.
LEO Privacy Applock Hide Safe Android Apps on Google Play
Anonymous
Level 2:
  • Expert 242 Answers
  • Posted on Dec 26, 2010
Anonymous
Expert
Level 2:
Answers
242
Questions
0
Helped
28952
Points
742
Switch off and switch on the mobile then check weather it is freezing again
I have windows xp and when i shoutdown the system it will freeze at shoutdown screen and also freeze in preparing stand by screen
Your operating sysem is corrupted and need to reinstall the operating system. or if you have the system back up file, try to run the back up files to solve the problem.
Freezing on windows mobile screen
It must have been something you have installed. I'm afraid you'll have to hard rest your device, to get past this problem. Be warned that all programs you have installed, as well as your personal data and settings, will be deleted, because your device will return to its factory defaults. Before you begin, your device's battery should be, at least, 3/4 full. If you are not sure, leave it connected to the wall charger for a couple of hours. Then, if your device is on, turn it off. Now turn it back on. As soon as you see the first screen, press and hold the Action button (the center of the D-pad), until a message comes up like 'Master Reset?' Relese the button and press the left softkey ('Yes').
Hope you are able to sort your problems out.
Cheers! Carlos
2answers
1helpful
Screen froze after installing WM 6.1
wiggle the stylus over the cross hairs until it moves around the screen and the screen alignment is completed. Then further software will self install and the phone shopuld be right
My dash keeps freezing up on the white tmobile page them on the windows mobile part ive tried holding the 2 button and the power button all it does is turn off and i tried holding the soft keys when...
first remove the battery then reinstall it, hold the 2 soft keys and the power button at the same time, do not release either, til the reformat screen appears... then press the green call button.
1helpful
Screen freezing on my moto q9h
You'll have to remove the battery. I had this similar problem with my Moto q9c. I ended up replacing the battery and haven't had the problem since.
Frozen screen
sounds like liquid damage
you can try to clean it internally, or wipe the charging port with a toothbrush and denatured alcohol.
1helpful
2answers
Dash Phone freezing up in the WHITE SCREEN
This may work for you
Will it just not boot up all the way but just stops?
If so try the procedure at this link: T-mobile Dash Master Reset
If this doesn’t work then proceed to the following guide below.
The Windows Mobile installation may be corrupted.
The only way to fix that problem is by re-installing the windows software on the phone.
from: http://www.howtofixmyphone.com/how-to-stop-t-mobile-dash-from-rebooting-over-and-over/82/
1helpful
2answers
Tmobile shadow cellphone
Power the Shadow off. Hold down the two soft buttons (The two right under the screen) and turn it back on. There should be a quick menu that pops up asking if you want to reset it. Say yes, let it reboot, and it will then start restoring your phone to defaults.
You will loose all your data.
2answers
Freezing at the windows mobile 6 load screen(spv m1000)
Hey, seems your operateing system is corrupted in the flash memory.
solution 1
Reflash the operateing system. If you have the knowledge on how to do so.
2. Take it to the shop where you bought it for repairs and analysis motherboard might be damaged.
Good luck.
If you need more asistance, let me know.
Top Palm Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
vince
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
