1 you said the cartridge is low.
it happens because the ink cartridge must have been used for initializing the printer which does take a lot of ink. please purchase a new cartridge and the issue will be resolved.
2 Try the following solutions in the order presented to resolve the issue. When one of the solutions resolves the issue, there is no need to continue troubleshooting.
NOTE:
If error messages also display on the computer, clear the error messages after each of the following steps. You might have to delete pending print jobs from the print queue on the computer to clear the error messages.
Solution : Clean the electrical contacts
Follow these steps to clean the electrical contacts on the printhead and inside the product.
CAUTION:
Follow these steps carefully to avoid damaging the sensitive electrical components.
Step one: Clean the contacts on the printhead
Follow these steps to clean the contacts on the printhead.
NOTE:
The ink nozzles on the printheads might clog if you expose them to air for more than a few minutes. The ink nozzles also might clog if you do not use the product for long periods of time.
Step two: Clean the contacts inside the product
Follow these steps to clean the contacts inside the product.
Solution three: Replace the printhead
Make sure that the product is turned on.
Open the top cover of the product.
Press and hold the OK button for five seconds. The carriage moves to the left side of the product. Release the OK button.
CAUTION: Proceed only if the carriage is on the left side of the product. If it is not, the printheads will be damaged when you install them. If the carriage does not move over, try turning the product off and on again
Wait until the carriage is idle and silent.
Lift the printhead latch.
Figure 5: Lift the printhead latch
Lift the handle on the printhead you are replacing, and then pull the printhead out of its slot.
Figure 6: Lift the handle to remove the printhead
Shake the new printhead package five to six times.
Figure 7: Shake the printhead package
Remove the new printhead from the package.
Remove the protective caps from the printhead.
Figure 8: Remove the protective caps
Insert the printhead into its color-coded slot. The label on the printhead must match the label on the printhead latch. Press down firmly on the printhead to make sure that the electrical contacts touch.
Pull the printhead latch all the way forward, and then press down firmly to engage the latch.
NOTE: You might have to press firmly to engage the latch.
If the error message indicates that both printheads are missing or damaged, repeat the steps in this procedure to replace the other printhead.
Close the top cover of the product. The product restarts and then prints an alignment page.
If these steps resolved the issue , you do not need to continue troubleshooting.
If the issue persists , continue to the next solution.
Solution four: Service the All-in-One
If you have completed all the preceding steps and are still experiencing a problem, service the product.
Determine if your product is in warranty or out of warranty. If you need help determining your product’s warranty status, go to HP’s Warranty Check Tool .
If your product is in warranty , contact HP.
If your product is out of warranty , fees might apply for contacting HP.
