Sorry to read about your problem, I hope this helps you out.
e90, means a bad connection. at the main control board.
you can try to open the machine and check a and clean all connections to the main board.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Hi
I assume you meant that I needed to pull out any connections and clean them? This I did not do as the area was pretty clean, only the plastic lower edge had a bit of grim on it. The problem is still there. I guess I may be a bit wary of fiddling around the computer pad (not sure what to call it) as i wouldn't like to cause another problem.
Thanks for trying to help.
