Question about Stanley Fatmax Xtreme Retractable Utility Knife
Describe how you put a blade in FatMax model 10-778
    Scholar:
  • 127 Answers
The model in your picture is a fixed blade utility knife (model 10-816). Your question asks for instructions for model 10-778, which is a retractable knife. I'll guide you through the 10-778 which you asked for, if you need instructions for the pictured 10-816 please re-post the question.
Push the thumb slide forward as far as it goes exposing the blade. Press the blade change button on the side of the knife (the small button on the left side near the blade) and pull out the old blade.
Insert the new blade and slide thumb slide back to fully engage blade in the internal lock.
Posted on Dec 27, 2010
SOURCE:
Can't close stanley fatmax
It only goes in one way, try to loosen the screw a little
Jul 30, 2012 | Stanley Fatmax Xtreme Retractable Utility...
I have a stanley fatmax knife but it doesn't have the small yellow button to help insert a new blade. what can I do?
HI!Kindly pull the button on the end of the knife and then after you remove that you can now put the blade of your knife.
Aug 21, 2011 | Stanley Utility Knife
How to open stanley fatmax knife 10-778 TO CHANGE THE BLADE. thank you
How do I change the blade on the quick change/instant change knife? Warning: Blades are sharp and can cause serious injury. Be extremely careful when handling blades. Wear eye protection and dispose of used blades properly, such as wrapping in duct tape.
FULLY EXTEND THE BLADE.
Press down and forward again on the slide button until the button is in the full front of the top slot (0 through 3 in the below picture).
Note- the blade must be extended beyond the 3rd detent position. This will cause the slide button to remain in a down position, allowing the blade release button to operate.
PRESS AND HOLD THE BLADE RELEASE BUTTON ON THE FRONT SIDE OF THE KNIFE. (Step 4 in the below picture)
Note- if the blade is not fully extended beyond position 3) , the blade release button will not work.
Remove the old blade carefully.
Insert new blade.
NOW, RELEASE THE BLADE RELEASE BUTTON.
ENSURE THE BLADE IS LOCKED IN PLACE. If the blade does not retract, try carefully giving a slight tug on the blade to reseat.
Jul 13, 2011 | Stanley Fatmax Xtreme Retractable Utility...
I cannot figure out how to put a blade in my Stanley FatMax fixed blade utility knife. There are no instructions with the knife.
at the handel end it will pull apartthen slide the whats left of the old blade and put new won in its place just do it slowly so you dont forget how it goes
Apr 21, 2011 | Stanley Utility Knife
I have a stanley FatMax. How do I insert the blade into the case?
On the side there is a big gold wheel, twist counter clockwise and the case should split in half, the blade is held by a magnet, prise the old blade off and replace with new one, then put case back together and tighten gold wheel clockwise
Mar 06, 2011 | Stanley Fatmax Xtreme Retractable Utility...
Cant put the thing back together after putting in new blade !!!fat max knife
some stanley knifes require stanley blades only, or make sure the clip blade is in is seated in the grove completely.
Dec 23, 2010 | Stanley Fatmax Xtreme Retractable Utility...
How do I put the first blade in the new knife?
open the blade all the way and turn the knob to loosen, then scissor the two halves to open
Oct 22, 2010 | Stanley Fatmax Xtreme Retractable Utility...
I brought a stanley fatmax retractable knife, have no idea why the blade is not coming out, trying to figure out if i did something wrong like putting the blade in the wrong spot.. this is the only time...
Are you using Stanley Blades or off brand? Hey, I use off brand but sometimes it does make a difference. Second, make sure the blade slider is clean. If you were cutting shingles, for instance, the tar gets in there and screws things up.. try WD-40 spray it liberally all over the blade slide and buttons. If that doesn't work and you purchased it at a Menards store, I can speak of experience they'll replace it no hassle.
I hope I helped
Jan 09, 2018 | Stanley Fatmax Xtreme Retractable Utility...
Stanley Fatmax Xtreme Retractable Utility Knife Logo
1,442 people viewed this question
Top Stanley Measuring Tools & Sensors Experts
Marvin
Marvin
Lawrence Oravetz
Frank Walton
Level 1 Expert
Are you a Stanley Measuring Tool and Sensor Expert? Answer questions, earn points and help others
