SOURCE: Emerson EWF2704 problem
Look for vertical output LA7804 7-PIN IC near right rear of set on heatsink. Look for bad solder joints in that area also.
SOURCE: Emerson 20" T.V. Green blobs
your tv has become magnetized the easiest way is to find a deguasing coil to demagnetize it however only services shop usally have those! you can try unplugging and turning set back on several times to see if that will clear it up as sets have a built in deguasing setup good luck from television tech!
SOURCE: I purchased a used Emerson TV Model 3 CR202EM8 and
go here if you cannot access the site: here are the instructions:
Your password will be erased and return to the default (0000) when a power failure occurs. If you forget the password, unplug the power cord for 10 seconds to restore
the password to 0000.
