Resolution : Fallow method 1 or method 2 no data will be deleted.To resolve this issue, you must have the Windows XP CD-ROM. If you do not have the Windows XP CD-ROM available,
If you have the Windows XP CD-ROM, use one of the following methods.
Method 1: Troubleshoot the specific element that causes Windows not to loadNote This option requires that you perform multiple steps to determine the exact element that causes the issue. This option may allow for you to keep customizations in Windows.
Method 2: Repair your Windows installationNote Repairing your Windows installation may change the configuration of Windows. You may also have to follow this step if you complete all the troubleshooting in steps option 1 and the problem is not resolved.
For more information about how to create a Windows XP boot disk, click the following article number to view the article in the Microsoft Knowledge Base:
305595 How to create a bootable floppy disk for an NTFS or FAT partition in Windows XP
315222 A description of the Safe Mode Boot options in Windows XPIf you can start the computer from the boot disk without receiving an error message, the damage is limited to the master boot record, the boot sector, or the NTLDR file. After Windows XP is running, immediately back up all data before you try to fix the boot sector.
Use Disk Management to view the partition information and to verify that the disk partition (or partitions) is correct. To use Disk Management, follow these steps:
If invalid partitions are present or you cannot start your computer by using a boot disk, consider reinstalling Windows XP on your computer and restoring your data and configuration information from a recent backup.
If you do not have a current backup copy of the data on the computer, contact a computer specialist to determine the best method of data recovery and configuration.
For more information about how to use the Recovery Console, click the following article number to view the article in the Microsoft Knowledge Base:
307654 How to install and use the Recovery console in Windows XPNote For more information about an error message that you may receive when you use the FIXMBR command, click the following article number to view the article in the Microsoft Knowledge Base:
266745 Error message when you run fixmbr commandWarning If your computer is infected with a virus and you use the FIXMBR command, you may be unable to start the computer. Before you use this command, make sure that the computer is not infected with a virus.
Windows XP Setup repairs the installation files, Windows XP automatically restarts, and then the Setup program finishes the repair of your Windows XP installation.
Note You must have your 25-character product key to complete these steps.
