Did you turn the radio on first. It must be powered up with the throttle stick at minimum. Turn power on and then move stick to maximum and back to minimum. The remote lite should stop flashing and then power on helicopter.
When the controller flashes, it means that it has not paired up the signal with the helicopter. Move the accelerator control (left stick) up and down quickly several times. The rotors should start to turn signalling that they are paired. Max out the stick forward and back quickly.
All mostly correct, but not completely. To operate the UJ once both the copter and remote are activated, move the throttle stick(left) to maximum, then back to minimum, return to maximum and wait there for about 1.5 seconds for the helicopter to activate. Be on the ball if you're indoors, as you'll be immediately headed for the ceiling at a high rate of speed. I like to launch out of my hand for this reason. The copter will activate on the first throw of the throttle from there on out until deactivation. Next use you'll have to repeat this process on the first flight. Also, keep an eye on the trim(wheel at bottom right of remote). When trim is properly adjusted you'll notice an increase in power and flight time.
Thanks, you solved my problem
mine still itsnt doing anything and the light on the remote is still blinking...no response from the helo
This does not answer my question
