I have this same problem any solution yet?
I HAVE THE SAME ISSUE, I SENT IT BACK TO GET IF FIXED AND WHEN IT CAME BACK IT DID THE SAME THING, I WILL NEVER BUY ANOTHE JURA PRODUCT
I had this problem. I tore it apart and cleaned various things, but no joy. I finally noticed that it would briefly work when I removed and reinstalled the water tank. It seemed like the check value in the water tank was sucking air, which didn't seem like the problem since there was NO leaking water. I bought a new water tank and that has fixed the problem for many months now. See if water flows shortly after you remove and re-install the tank.
Turn Off the computer now as soon as you hit the power button, keep on holding Alt key & keep on tapping F10 key ie: Alt+F10, it will open the recovery console select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to hope this helps you
hope this
helps
