It sounds as if the files system has become corrupt after the break in connection. You can only now connect the drive to a system running Linux or use a bootable Linux disk in your pc and see if it can recognise your 5000bev. If you can see your data the copy it to another good drive. You should now be able to use it.
SOURCE: The file system of my hard drive become RAW.
http://www.z-a-recovery.com/unformat-tutorial.htm
This tutorial describes the procedure to recover one volume when
The recovery is done in seven steps, requiring about eleven (11) mouse clicks.
Note: The older than current versions of ZAR might have been used to create the screenshots in this tutorial. We did not update the screenshots if there is no significant difference between older and current versions. If you see some option in the program which is not described in the tutorial, just leave it at its default setting.
Step 1 - Get, install, and start ZAR
Download and install ZAR just like you do with any regular program.
When you run it, ZAR displays the window like the one below:
Step 2 - Select processing mode
Step 3 - Select physical device to recover
