SOURCE: Zyxel P660HW-D1 drivers
Since you are referring to a router you can access the configuration using the web configuration you just need to type the router default ip address on your browser to access the configuration.
the default ip address is 192.168.1.1
http://www.zyxel.com/web/product_family_detail.php?PC1indexflag=20040812093058&CategoryGroupNo=AC5783AE-9475-41AD-BDA5-0997187F44AA
http://dl01.zyxel.com/DownloadLibary_ShortName/P-660HW-D1/quick_start_guide/P-660HW-D1_1.pdf
SOURCE: My NAT setting is to strict to play xbox live.
You'll just need to open the port number for the specific game that doesn't play. Click the link below for the port number of your game. Use port forwarding feature of the zyxel when opening the game port.
Click HERE
SOURCE: Zyxel P660HW-D1 upgrading the antenna
The internal address is 192.168.2.1. Default pass should be 1234. Hope this helps you.
PFC. Aaron Ramos
SOURCE: i need router configuration password for Zyxel P-660H-D1 modem
Download a userguide from http://us.zyxel.com/Support/Download-Library-Result.aspx?mif=20050726121025
I think the password is 1234 for admin mode
SOURCE: Im trying to change my
You know, i had a similar problem, and i think its a glitch in the system. Take your console and play somewhere(not at home) with a STRICT NAT type; i did it, and when i plugged it in at home, it was open. It was weird, but its worth a shot.
