Hi The problem may be with the game. some PS2 games are partially compatible with PS3. When the controller vibrates and turns off use the wire to switch it on and keep running.
It should sync after connecting it with a cable to the PS3. If not, try turning off the PS3, then holding the PS button on the controller near the PS3. This should detect it and turn on the PS3, syncing the controller in the process.
1. You need 3 other controllers besides the Nyko guitar (they can be the rockband instrument set, or just any PS3 controllers. I used a DS3 a RB guitar and GH3 guitar) 2. You need all 3 of the controllers assigned to the PS3 taking up spot 1-3 except the Nyko guitar (goal is to assign the Nyko to 4 or higher) 3. Plug in the Nyko dongle and attempt to link with the guitar (it will most likely make the Nyko button turn red which is the color that won't play) 4. Turn the switch on the dongle back and forth once or twice ending on GH setting letting the guitar link on it's own (It may not assign correctly on the first try, but keep switching between Rockband setting and GH setting. Always end on GH, because it will work with Rockband on GH setting) 5. After a few times it should link and allow you to play
Problem is the firmware of the PS3 (V3.10 or higher)
