How to increase Virtual Memory?
In Windows XP
1.Click Start, and then click
Control Panel.
2.Click
Performance and Maintenance, and then click System.
3.On the Advanced tab, under Performance, click
Settings.
4.On the Advanced tab, under
Virtual memory, click Change.
5.Under
Drive [Volume Label], click the drive that contains the paging file that you want to change.
6.Under
Paging file size for selected drive, click to
Custom size check box. You can enter the amount of memory you would like to reserve for Virtual memory by entering the initial and maximum size.
7.Click
SetWhen you are prompted to restart the computer, click Yes.
Special Note: You should choose the same amount for the initial size and maximum size. This will Stop your CPU from constantly changing the paging file.
HOT TIP: To stop your CPU from constantly changing the paging file, set the initial and maximum size to the same value. For example, 500 and 500. The value should be at least 1.5 times more than your physical RAM. If your computer has 512MB of RAM increase the virtual memory paging file to 1.5*512= 768
In Vista
1. Click
Start button Picture of the Start button
2. Click
Control Panel3. Choose
System and Maintenance and then click
System.
4. In the left pane, click
Advanced system settings.
5.On the Advanced tab, under Performance, click
Settings.
6. Click the Advanced tab, and then, under Virtual memory, choose
Change.7. Click
Custom to change the Initial size (MB) and Maximum size. See the hot tip above.
Remember to choose the drive you would like to use to increase the virtual memory. In most cases it usually your C: Drive. You can set the initial size and maximum size after clicking the Custom size check box.Remember its better to keep the Virtual memory values the same.
Also having enough available space is absolutely necessary for your virtual memory and RAM to function properly.
