Heating & Cooling Logo
Posted on Dec 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When am switch on the air condition displaying error f8
R Subramaniyam Iyer
Level 3:
  • Master 2,133 Answers
  • Posted on Dec 25, 2010
R Subramaniyam Iyer
Master
Level 3:
Answers
2133
Questions
Helped
953279
Points
6173
Code F8
Error detail Input circuit fault. Check indoor fan mechanism locked or no power to voltage. If no power to motor replace PCB. If power and still your motor locked replace motor. Is it helpful?
3answers
Voltas ac error code F8, what's the problem & how to solve f8
F8 problem on voltas inverter a/c, How to solve this problem
What must we do to rectify an F8 fault?
I went to the roof and turned the unit off, waited a minute and turned it back on and the unit worked fine after that. It was a power failure that messed ours up.
21helpful
3answers
My samsung inverter condition does not switch off error C1
Try:
Switch the unit off with the remote (power button) - "C1" appears on unit
Push "Auto Clean" button on remote
Unit should switch off
Jenn-air w276w oven gives error code F8 and beeps continously. How to reset?
F8 means "Analog / Digital problem" and it means that you have to replace to replace you display board. You can try to find a circuit breaker on a side of your house and switch it off and back on (should be a double breaker, at least 40 amps).
Oven repair in Santa Ana, CA
Appliance repair in Santa Ana, CA
6helpful
I have waves split air condition its cooling is good but some time in the display e4 is coming and that time my ac is not giving cold air what is this.tell me some one.
The e4 that displays on your air condition come up simply because there is an error during the operation of the system. E4 means Error 4 which is a code that is interpreted as low pressure switch.
E4 simply means there is low pressure switch, the pressure switch turns on automatically inside the air condition, so when you turn it on sometimes the switch jams and does not open so the air condition will be on but would not get cold because the switch jammed and it displays an error signal to let you know there is a problem in the system.
Take care
6helpful
2answers
F8 error
F8 on tamashi ac
7helpful
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F4 Shorted wire or Sensor locate short and correct it
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F2 Oven over heat Replace defective Sensor
F7 Shorted Touch Panel Replace Glass Panel
F9 Door Latch Error Check latch
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F1 Defective ERC Replace ERC
F3 Oven Sensor Open Check/Replace Sensor
F5 Defective ERC Replace ERC
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
F8 Defective ERC Replace ERC
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
F0 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F9 Door Latch Error Check latch and latch circuit
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 18, 2009 • Ovens
Top Heating & Cooling Experts
Paul Carew
john h
