b>
b>I think it could be due to virus activity. Some virusmake the contents of the drive hidden, that's why user can't see the
files and the space available for use is less than thecapacity and also can not open the drive.
It issuggested that go to FOLDER OPTIONS - and select SHOW HIDDEN FILES. It may showthe hidden files.
If can not show ,hidden file (tools >folder option>view> check on show hidden file>check off hide protected and checkoff hide extension) now can see all hidden file in c drive. If not think......
For ensure again
run>type> msconfig > hit can not open ms config if virus effected
run >type> regedit>hit>can not open registry if virus effected
run >type >gpedit.msc>hit can not open group edit policy if virus effected
Otherwise, ifyou don't have any vital data on the drive, just format it in another pc.Pleasenote, before insert the
Pen drive .Go to run command from start menu OR Press Win key+R and type gpedit.msc and hit>Usser configuration
>system>turn off auto play >enable>use down arrow key select all drive >apply >ok. Control panel>administrative tools > service>select any word in right side and presss for select Shell Hardware Detection> d -click >use down arrow key>disable >start. And now can insert pen drive and format. Hope this wouldfix the issue and
Youshould fully scan by f-secure bootable cd or any another antivirus bootable cd.Just insert the disk and restart.
Follow bellow the download link.
http://www.askvg.com/download-free-bootable-rescue-cds-from-kaspersky-bitdefender-avira-f-secure-and-others/
you wouldbe able to enjoy the full capacity of the disk. Try to be sure follow these youshould delete partition and create new partition and format your all drive.
Now install fresh O.S.Hope it will help you.
