Nvidia GeForce 6600 Graphic Card Logo
Posted on Dec 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It is working but with fine lines.waht to do?
Anonymous
Level 3:
President:
  • Master 1,812 Answers
  • Posted on Dec 25, 2010
Anonymous
Master
Level 3:
President:
Answers
1812
Questions
0
Helped
527851
Points
7608
Hello ,
Please go their website and download from there.
http://www.nvidia.com/Download/index.aspx?lang=en-us
Follow all the steep.
Product Type: GeForce ION Quadro NVS 3D Vision nForce Tesla Legacy
Product Series: GeForce 500 Series GeForce 400 Series GeForce 400M Series (Notebooks) GeForce 300 Series GeForce 300M Series (Notebooks) GeForce 200 Series GeForce 200M Series (Notebooks) GeForce 100 Series GeForce 100M Series (Notebooks) GeForce 9 Series GeForce 9M Series (Notebooks) GeForce 8 Series GeForce 8M Series (Notebooks) GeForce 7 Series GeForce Go 7 Series (Notebooks) GeForce 6 Series GeForce 5 FX Series GeForce 4 MX Series Product: GeForce GTX 580 GeForce GTX 570 Download Type: Driver Software HDMI Audio Driver Download Type: Quadro Graphics Driver Quadro Performance Driver Quadro Partner Certified Driver AutoCAD Performance Driver 3ds Max Performance Driver Mosaic Utility Download Type: Graphics Drivers Chipset Drivers HDMI Audio Drivers Operating System: Windows 7 32-bit Windows 7 64-bit Windows Vista 32-bit Windows Vista 64-bit Windows XP Windows XP 64-bit Linux 32-bit Linux 64-bit Solaris x86/x64 FreeBSD x86 FreeBSD x64 Language: English (US) English (UK) English (India) Chinese (Simplified) Chinese (Traditional) Japanese Korean Deutsch Español (España) Español (América Latina) Français Italiano Polski Português (Brazil) ??????? Other
Toro snowblower wont start.I have a toro ccr powerlite that dosnt seem to be getting fuel from the fuel line into the carb. I took the fuel line off and fuel is getting to the carb so then i removed carb...
Reference the Toro snow blower. It may sound crazy but loosen the gas cap just a bit. I had the same issue with my snow blower and a friend gave me the solution. It works great now. Hope this works for you.
Had the Moen L82691 installed about 2 weeks ago. It worked fine, however now it only produces hot water. Even on the cold setting the water gets hot.
I think Moen is one of the easiest to work on and most trouble free there is. The only problems I have ever encouneterd with them is the mixing valve.This is the parts breakdown:
http://www.moen.com/shared/docs/exploded-parts-views/l82691pt.pdf
and a video
http://www.youtube.com/watch?v=J-SNBNijfQc
Of course you handle would have the set screw that holds it on. I would go to who ever you got the valve from and see if they will give you a new valve or, the video states Moen may provide a new one free. It's also possible, being a new install, that you may have had junk in your water lines that have now plugged the cold side of the valve. If you have some help, you may want to have someone taht can turn water off and on(slowly), cold first, and see waht kind of flow you have with valve out. Check for trash in the line and the valve first.
May 29, 2011 • Home
I have a 8250 Photosmart printer , it was working fine until 3 days ago, noticed more reddish black where there should be black. Cartridges showing good, waht could be my problem?
Sometimes the cartridge will show "good" when they actually need to be replaced. Try printing a test page, cleaning the ink nozzles, and if the problem persists, replace the ink cartridges.
2helpful
2answers
AC is blowing cold air, but it is coming out of the defrost and not the front vents. Why are the front vents not working?
Check over on the passenger side under the hood by the fire wall, there will be some elec. connection, just below that there will be a small vacum line that should go into your fire wall, check that it has vacum, it should also have a one way valve, small round looking some time that get clog, needs to have vacum that is what power the blend door's.
Horn not working
remove the steering wheel to check the spring brass connector
White smoke
Sound most likely like a head gasket - Check your coolant level and if low it is possible that coolant is entering into the engine. I would not driving the vehicle as driving the engine would cause more damage.
My jazz dv 179 wont turn on plz help me
did you put a sd card in it? if so, reformat your card.
2answers
Hp laserjet 4250dtn PROBLEM
try replacing the toner cartridge, if that doesnt work, let me know
Top Nvidia Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
