SOURCE: Oreck XL Leaks Dirt At Bag Entrance
do you use a docking station to put your bag on or is it just a push on bag? also when you turn on the vac with an empty bag in it, does the outter bag blow up?
SOURCE: Delta 36-075 miter saw. Motor ok, but blade will not spin
It sounds as though one or both of the items are stripped. They mesh to drive the blade so I would not take a chance on just replacing just one. Also when you look at this you might also want to look at replacing the bearings and brushes. Make sure you clean out the gear housing or you will have immediate problems again. Also check where you buy these parts for their recommendation on the grease that needs to be used.
SOURCE: Brake Rotor Removal.
you might need a wheel puller and a little bit of PB blast and you can try www.autozone.com to see if they have your car listed for diagrams pictures and step by step instructions if your car is not listed then try your local library they have all the car manuals and even copy them for you
SOURCE: My son has broken the plastic spacer piece
Most parts are available at http://www.wahl-store.com/ under "accessories" the 9918c is a "groomsman" model.
SOURCE: Hi. I bought an AMT Millenium Falcon model kit
Hi Robert, I think I can help. I recently found this site with a lot of information about star wars model kit.
Go to this link about the AMT Millenium Falcon Cut-away version
http://www.starwarsmodels.com/mfca.html
There is a download link to the right which contains the original instructions. Even if you don't have the cut-away version I'm sure this will help!
Jim
