1994 Honda Prelude Logo
Posted on Dec 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have honda city 1994 model, pls advice me on how to change front wheel axle/cv joint/boot thanks madaan
William Robinson
Level 3:
Genius:
  • Master 1,547 Answers
  • Posted on Dec 25, 2010
William Robinson
Master
Level 3:
Genius:
Answers
1547
Questions
0
Helped
502411
Points
4729
  • Loosen the lug nuts (turning counter-clockwise) to finger tight on the front wheel with the damaged CV joint. Buy, borrow or rent a CV nut socket. Some auto parts stores will sell you one for about $30 and refund your money when you return it. Because the CV nut in the center of the wheel hub is locked in place with a safety tab, it is loosened initially with a long breaker bar or a hollow pipe placed over the ratchet handle to increase the torque needed to break the nut free. Loosen to finger tightness.
  • 2 Set safety brakes and jack up the front of the car toward the side of the damaged CV joint using at least a 2 1/2-ton jack. Both the car and the jack should be on a hard, level surface and the lifting point must be a load-bearing member on the chassis or engine cradle. Place two jack stands under the front end and slowly lower the car onto the jack stands so the car chassis is fully resting on the stands. Now, pull out the jack and move it out of the way.
  • 3 Remove the wheel lug nuts and pull off the wheel from the hub. If it doesn't cooperate, kick the bottom of the tire sidewall with the back of your heel or the flat of your hand to dislodge it. Unscrew the center CV nut. To dislodge the male spline outboard end of the CV joint that fits into the female spline in the back of the wheel hub, take the CV nut and screw it back on three or four turns, then strike it with a hammer to partially disengage the splines.
  • 4 Remove the ball joint stud on the lower control arm from its socket in the spindle behind the wheel hub, after you remove a locking bolt, cotter pin or other device that holds the ball joint stud that protrudes from the lower control arm. Then, wedge a pry bar (called a pickle fork) between the tie rod and sway bar. To gain greater leverage, insert the pry bar handle into a length of pipe and apply downward pressure to remove the ball joint stud from the spindle.
  • 5 Remove the CV joint and shaft. With the lower ball joint disconnected from the wheel spindle, the hub can be moved to the side just enough to remove the outer CV joint from the spindle socket in the back of the wheel hub. Do not stretch the brake line that is attached to the wheel brake cylinder as you move the hub aside. With the outboard end of the shaft free of the wheel, pull the shaft straight out from the transmission housing. Because of the labor involved with repairing or replacing CV joints, it's more cost effective to simply replace the entire shaft assembly including the two CV joints and boots.
  • 6 Install the new shaft and CV joint assembly. Clean the transmission seal that came off the old unit; pack it with grease and place it over the inboard spline of the new unit before inserting new shaft into transmission. Make sure splines are lined up before tapping the other end of the shaft with a hammer to seat it in its socket. Carefully insert the other end of the shaft back into the wheel hub and loosely thread on the new CV bolt that came with the assembly.
  • 7 Reinstall the ball joint stud into the spindle by re-inserting the pry bar between the tie rod and the sway bar and leveraging down the lower control arm with the ball joint stud positioned just under the spindle hole. Then release pressure on the pry bar so the ball joint stud re-seats into the spindle. Push the wheel hub all the way onto the shaft spline to seat and torque down the CV nut tight. With a flat head screwdriver tap the lip of the new CV nut into the groove cut into the screw end. Now, re-attach the ball joint locking bolt, put the tire back, replace lug nuts and tighten. Remove the car from the jack stands and finish tightening the tire lug nuts.
  • Add Your Answer
    1helpful
    2answers
    Hi there I want to know if the SVX cv axle is same axle as the impreza, legacy and forester? Thanks
    Yes the early subaru's all use the same front and rear axles
    Fronts are easy to change. rears are not.
    The only difference in the early style axles that use pin on inner joints are the outer joints with abs rings.
    Cv joint and boots
    Hi Wendy Ann,
    Hard to give an exact diagnosis when I can not hear the noise myself. Generally, a bad CV joint will make a clicking sound when you turn a corner. From what you describe, it sounds like you've been ignoring the problem for some time. Due to the mileage on your car, I would recommend that you change both front half axle assemblies. [There are two CV joints/boots on each half axle] This is a common problem on front wheel drive cars.
    2answers
    Where is the cv joint
    Hello harborviewdo. My name is Roger and i will answer your question. Your vehicle has two drive axle half shafts. One on each side of the transmission. The out board side of each shaft is called the outer cv joint. Generally when they are bad you will find the outer boot is torn and has thrown the grease out. Should you need further help please just ask. Please rate the answer you received. This way I know it was helpful. Thank you for using Fix Ya. Roger
    Heard loud clunk while driving, now it wont move in any grear?
    Your CV joint may have failed and and will need to be replaced. Inspect the left and right CV joints for any signs of damage. Cv joints are the left and right axle from the transmission to the left and right front wheels.
    Thank you for using fixya and be safe.
    1helpful
    3answers
    Kia spectra model 2000- rough sounds from the front right wheel when making u turn
    Probably cv joint they will start that way when on the straight away you wont hear it but on the turn you will means that the bearings in the cv joint are bad check this out and let me know also please rate my assistance if it was helpful thank you.
    1helpful
    2answers
    My 1992 Honda Accord EX-R makes a clunking/rattling sound...
    It's probably your cv (constant velocity) joint. Jack up the honda and put it on safety stands, look at the area behind the center of both front wheels, there is a rubber boot. This boot protects the cv joint from dirt, road grime, water, salt, etc. If you see splits in it or grease on the boot, it has deteriorated, and is letting contaniments in. The damage has already been done if it makes a rattling noise going around corners at slow speed. I changed both cv joints (purchased rebuilt axles for $49 each) in my 92, but it is a big job labor wise. There's a lot to take apart to remove the axles.
    2answers
    Inner cv joints
    inner cv joints are the joints on the inner half of the axle shaftswhere they go into the transmission. sometimes the easiest thing to do is replace the axle shafts
    Top Honda Experts
    ZJ Limited
    ZJ Limited
    Thomas Perkins
    Thomas Perkins
    john h
    Are you a Honda Expert? Answer questions, earn points and help others
