Hello there:
here is a discriptive way of trouble shooting the dryer and it lists the common components that will normally fail if the element has not failed first
Gas Dryer Diagnostics
This picture shows the main parts of a gas dryer's burner systemthat can fail. Understanding each component and it's failure mode canreally help diagnose a problem with a gas dryer.
Ignitor failure: The drum turns but the igniter doesn't glow, thereis no clacking sound as the gas valves open and there is no flameignition sound.
Radiant Sensor failure: The drum turns but the igniter doesn't glow,there is no clacking sound as the gas valves open and there is no flameignition sound.
Gas Valve Solenoid failure: The drum turns and the igniter glows andgets turned off but there is no clacking sound as the gas valves openand there is no flame ignition sound.
And another component failure to be aware of, but that's not shown here, is the operating thermostat:
Operating Thermostat failure: The drum turns but the igniter doesn'tglow, the gas valves don't open (there is no clacking sound) and thereis no flame ignition sound.
And here's a picture of other components to ohm out if you're getting no heating at all:
