Question about HTC Radio Communications
Hello. I have an HTC Desire. I have this problem with adjusting the volume sound, when i am listening to music. (the media sound) This is only when I use my headphones. I use normall Koss headset. This has worked just fine for over 2 months. But all of the sudden, when i connect my headphones, nothing happens when i try to adjust the volume..
6ya staff
SOURCE:
Anonymous
  • 72 Answers
SOURCE: listen to music
You defently can. I do with my moto q and my h700
Posted on Feb 15, 2008
Buschchris1
Chris Busch
  • 474 Answers
SOURCE: Can't adjust the earphone sound
Use the side buttons to lower the master volume, when your in media mode listening to your music, you have to use the side buttons or flip it open and use the side buttons by squeezing your finger between the big screen and the keyboard, they diodnt think that part out to well.
The ear Piece volume control your talking about only pertains to when your actually on a call.
Stupid set-up i know.
Posted on Feb 18, 2008
jerryg50
Jerry Greenberg
  • 1691 Answers
SOURCE: logitech usb headset a-0356a trouble hearing
I don't have these headsets here and the setup to troubleshoot for your fault. But, I have an opinion.
It seems that the driver for the headset is not routing the sound from the net or other applications to the USB ports, as like with the sound from the media player.
For IE, look in the advanced settings for media and see if there is a setting for this. Also, check out all the media settings in the system for this.
I would search out the properties of the headset to see if there is a setting for this. Also search out the properties of the sound card where it allows for USB and regular sound sharing or routing.
I would also get in touch with the manufacture of this headset to find out if they know something or have a solution.
Jerry G.
Posted on Apr 13, 2008
Anonymous
  • 59 Answers
SOURCE: headset volume adjustment
if connected to a pc right click on the speaker icon on the right side of the main toolbar in windows then click on playback devices and adjust the volume there.
Posted on Apr 05, 2009
Anonymous
SOURCE: Motorola S805 headset worked fine with T60 laptop
Solution I found with the same devices is to properly par the devices.
Refer http://direct.motorola.com/ens/s805/QuickstartGuide.pdf
It basically states :
1.Ensure the headphones are turned off (L indicator light not blinking).
2.Press and hold L button. After about 6 seconds, the L indicator light becomes steadily lit.
3.Release the L button. The L indicator light remains steadily lit.
If the L indicator light is flashing or not steadily lit, repeat steps 1 through 3
Now on the T60:
Search for Bluetooth Devices as you would normally.
The T60 lists Bluetooth devices it finds.
Select Motorola S805.
Select OK or Yes to pair your headphones
with your phone.
Enter the passkey: 0000
Select OK.
When your headphones successfully pair
with your phone, the L indicator light
changes from steadily lit to rapidly flashing.
That's it next time you start a audio program on T60 output will be sent to Motorola Headphones
Posted on Jan 28, 2010
Htc volume control won't work
You can always go into the settings and sound options to adjust it manually. The buttons may just not work. If you can be more descriptive I can provide a more in depth solution if necessary.
Oct 27, 2012 | HTC Desire Cell Phone
Tip
How to copy iTunes AAC(M4P) WMA Music to HTC Evo 4g, HTC Desire, HTC Incredibe
Quoted from: Transfer iTunes to HTC Evo 4g
Q: "I have some AAC Music I bought from iTunes but when I put some of them on my HTC Evo SD card it says this Music cannot be played. Is there any way around this? Or an app I can get?"
A: "Here is the thing, Apple's iTunes AAC (m4p) music and other protected WMA music with DRM protection can't freely transfer or playback on other devices, If you want to play iTunes AAC music on your HTC EVO 4G, you just need to use some DRM Converter software to convert the iTunes music to HTC EVO 4G compatible format."
This Text will show you how to remove DRM from iTunes music, Convert DRMed iTunes AAC(M4P) M4A WMA to MP3 and transfer to HTC EVO 4g, HTC Desire, HTC Incredible
Step1. Free download Daniusoft DRM Converter, install and luanch it, the default settings work well with your PC, you don't need to make anymore configeration.
Step2. When come to the main interface, click "Add" to import DRM license protected music video files from iTunes or common files you want to convert.(you can right click on a song in iTunes, select "Get Info", and it will tell you where on your computer that file is located)
Step3. Choose the target output format you need.( HTC Touch Evo 4g/Desire/Incredible compatible audio fomats: MP3, WMA, AAC ,etc and Video fomats: MP4)
If you want to customize output setting, just Click "Settings", there will be a pop up window displaying the output settings parameter, such as Formats, resolution, frame rate, bit rate etc.
Step4. Convert iTunes to HTC Evo 4g or HTC Desire/Incredible
After finishing all the necessary steps, you can click "Start" to start converting your file. When the conversion progress reaches 100%, the DRM Copyright protection on iTunes is removed and conversion is easily done!
Step 5. Transfer converted iTunes Music to HTC Evo 4g, HTC Desire/Incredible
After you get the output music files, you can connect your HTC EVO 4G or HTC Desire/Incredible to your computer via USB, select Disk Drive when your phone asks. Then go to My Computer and click on your phone. it should appear as an external hard drive. There should already be a music folder with the preloaded songs there. You can now just copy the music of your iTunes into that folder and your HTC EVO 4G or HTC Desire/Incredible will now have all your music in the Music app directly.
remove drm from wmv ' iplayer ripper ' remove drm from itunes 10 ' itunes to droid ' Transfer itunes music to htc evo 4g ' wmv to ipod touch 4g ' drm removal ' convert m4p to mp3 ' amazon video on demand ipad ' remove drm from itunes ' remove drm from nokia music store ' m4v to droid ' iTunes to galaxy s tab
on Oct 23, 2010 | Cell Phones
Hi the sound for the music player is not very loud unless you put the ear phones in ?
Hi, I have two reasons in mind why this might be;
1: The media volume on the phone may not be turned up all the way, check the Media volume and not just the ringer volume.
2: The speakers on the phone itself may not be designed to be very loud when it comes to playing music, the varying frequency ranges are difficult to pump out at loud volumes with such small speakers. Developers of the phone may have just anticipated users of the music player would always listen with headphones.
If you want a phone to play loudly without having headphones in, specify such a desire to a sales rep in a store so they can suggest the phone that meets the needs that are most important to you.
Good Luck hope this helps
Mar 11, 2011 | Samsung Galaxy S GTI9000 Smartphone
Como hago para conectarlo directamente al televisor? no me da sonido
Home speaker systems experience malfunction either because the music being played is inappropriately recorded. First attempt to select from the list of media music or video to ascertain the condition as recording related. Second, the adjustments on the media player equalizers mentionable as bass or treble of teeters audibility makes the type of sound preferred. Open to display the computer media player to select from the audio sound adjustment qualities. Most computer media players have auto sound adjustments either mentionable as jess, pop, reggae, as only mandible examples of regulating the sound quality features. Navigate through the media player to ascertain the most appropriate volume; sound ratios require achieving pleasant listening experiences. For example, ascertain from the speakers systems for any available volume adjustment buttons. Also, the media player has adjustments to volume where the computer task bar area has adjustment volume bottoms. Observing queenly the sound features on the computer repair restoration functionalities.
Feb 02, 2011 | Cyber Acoustics CA-5001 Computer Speakers
My speaker system was humming loudy and now only makes a loud static noise.
you might have to uninstall then restart your computer then reinstall both the drivers and the sound devices
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver
or
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Feb 02, 2011 | Altec Lansing AVS 500 Computer Speakers
I forgot my screen lock password
First im really sorry about that! to fix the issue you must do a hard button reset. if you go to http://www.knowyourcell.com/htc/htc-desire/desire-guides/443117/how_to_hard_reset_the_htc_desire.html
it provides the steps as follows:
Please note that all data will be deleted from the HTC Desire as a result of this procedure. This process does NOT delete data stored on the microSD card. We recommend backing up all of your personal data before proceeding.
  1. Turn the power off. If your HTC Desire is frozen, pull the battery out and reinsert it
  2. Hold the Volume Down button
  3. Press and release the Power button
  4. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
  5. Select Clear Storage by pressing the Volume Down button
  6. Press and release the Power button
  7. Now simply confirm your decision: Volume Up for YES and Volume Downfor NO
If you selected YES, all data including third-party applications will be deleted from the HTC Desire. Once the wipe is complete, the phone will reboot to its factory fresh state.
i am 100 % sure this will fixya for sure!!
Dec 24, 2010 | HTC Desire Cell Phone
I want to know how to transfer video, music, and othjer media files to my htc desire
You just need windows mobile device center on the computer. Then connect with either bluetooth or usb cable.
http://www.microsoft.com/windowsmobile/en-us/downloads/microsoft/device-center-download.mspx
Thats It. you can then move files from the computer to the desire or vice versa.
Oct 03, 2010 | HTC Desire Cell Phone
How do you get your 6700 to play music etc on the headphones
Your phone includes a media player for listening to songs and viewing video clips. Music and video files stored in the music folder in the phone memory or on the memory card are automatically detected and added to the music library.
To open the media player, select Menu > Media > Media player.
Music menu Access your music and video files stored in the phone memory or on the memory card, download music or video clips from the web, or view compatible video streams from a network server (network service).To listen to music or play a video clip, select a file from the available folders and Play.
To download files from the web, select Options > Downloads and a download site.
To update the music library after you have added files, select Options > Update library.
Play songs
To adjust the volume level, press the volume keys.
Operate the player with the virtual keys on the display.
To skip to the beginning of the previous song, select icon_28.giftwice.
To rewind the current song, select and hold icon_28.gif. Release the key at the position you want to continue the music playback.
To close the media player menu, and to continue music playback in the background, press the end key.
To stop the media player, press and hold the end key.
Hope it helped.
Nov 22, 2009 | Nokia 6700 Classic Cell Phone
Dec 31, 2007 | LG enV VX9900 Cellular Phone
Radio Communications Logo
37 people viewed this question
Top HTC Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a HTC Radio Communication Expert? Answer questions, earn points and help others
