Hi
on your cable box, check if you do have a digital audio out. if so, then you should opt for a digital optical audio cable and connect it to your cable box, and then to your htc-555. (At the back of your htc-555 you have a digital audio input.)
You will have to connect an audio output from the tv to the sourround reciver. you should have some audio output on the back of the tv and a corresponding input on the samsung ht c555
hi ref my samsung ht c555 home cinema will it bebest to use digital optical cable and splitter to all the equipment and thanks for your help
hi
for optimum sound you should use the digital optical cable as you said. However if you want to connect several peripheral (such as psp3, skybox, dreambox etc) to your surround system you should buy a switch and not a splitter. a switch is multiple input and single output...thus you connect all the peripheral you have to the input side of the switch and the single out to the surround system. Then through the switch one can choose which peripheral to be connect to the surround system. A splitter won't work, since it is based on one input to several outputs.
hope this gives you a clearer idea.....
indri.
Samsung HW-C500 Plays FM OK so I know output to speakers is OK. Also plays music CD's OK.
But will not play from Samsung iPod dock connected to HW-C500.
Doesn't show iPod menu on TV screen either.
