Model:spd-s sampling pad,Roland.when i open the system it's showing memory damage. we used it last week also. we bought it two years back.we dont use it so frequently.we went to the shop from where we bought it but they could'nt do anything.
I have the same trouble. Upon bootup, the display shows "memory damaged" and no sound is played. The display offers to press to initialize, but this also fails.I have the same trouble. Upon bootup, the display shows "memory damaged" and no sound is played. The display offers to press <enter> to initialize, but this also fails.
You can't post conmments that contain an email address.
The adaptor for the SPD-20 is not 12 V ac (Altern Current) the SPD-20 need only Altern current (12V AC) if the adaptor is 12 v cc, the internal circuits can not made +5v , 0, -5v for simetrical operactional supply. And Spd 20 show "Analog test err" and "batery low"
Use the following procedure to turn off wave protect: 1. Power on while holding SETUP and WAVE ("Welcome to SPD-S",
followed by "wave protect off" will show momentarily in the display). Note: Repeat the procedure to turn wave protect back on.
You can reset Roland SPD-S by using Roland SPD-S utility CD supplied with product. If you can't locate (or lost) the CD that is included with the SPD-S which contains the factory data, you can download the file here:
if you have the samples in .WAV then you will have to IMPORT them, because SPD-S can only play .SPD files (import will convert from WAV to SPD).If you have produced your samples with your SPD-S (via mic or line-in or PhraseMaker) then they are already in .SPD-format and can be assigned without importing. In this case you just have to assign a sample to a pad, by pressing CARD ("card"=lit) you can assign samples from your CF-card to a pad.
