Cycling Logo
Posted on Nov 04, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Forza model mens bike. I ride with the seat fully raised. However I have to bend down too much to reach the handlebars. My question is is it possible to raise the yoke in the front forks in order to raise the handlebars.....this does not appear to be possible. Alternatively do you sell a longer yoke which raises the bars?
John P Mayer
Level 1:
Habit-Forming:
New Friend:
  • Contributor 34 Answers
  • Posted on Nov 09, 2017
John P Mayer
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
34
Questions
0
Helped
12535
Points
96
Ok, first thing have you loosened and adjusted the yoke out to its full extension. There is an interior pinch cam that tightens up against the stem when you tighten the yoke screw. If your yoke stem is not long enough a good bicycle shop should have an extension Yoke stem or they should be able to order one for you.
Donald Ayers-Marsh
Level 3:
  • Lamborghini Master 1,389 Answers
  • Posted on Nov 04, 2017
Donald Ayers-Marsh
Lamborghini Master
Level 3:
Answers
1389
Questions
0
Helped
559242
Points
6679
You may have a bike that is too small for you. If you are unable to return it the stem can be replaced by one that raises the bars more or that does not go forward as far, or the bars can be raised by using what is called a "stem riser". It is best to refer to a bike shop for info on purchasing the correct stem/riser or installing such an item, but below is an example of one stem riser and install videos.. Origin8 Tra Lift Stem Riser 75mm Black 1 1 8 stem riser Google Search
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
5 Related Answers
Anonymous
  • 141 Answers
  • Posted on Jan 22, 2009
SOURCE: I need to raise the handlebar height on my 26" bike.
On the neck, the bolt would be at the top, dead center, screwed down inside the neck. Loosen it about 5 full revolutions. Then take a hammer and tap it back down. Lift the handlebar to desired height, and hold it there 'til tight. Also while it's a little loose turn it clockwise/counter clockwise, to make the bar straight (while holding the front wheel) before fully tightening. Then your done! Glad to help. Best wishes to you.
goalie39
Ed
  • 479 Answers
  • Posted on Apr 24, 2009
SOURCE: how to raise handlebars on diamond back outlook
If it is a conventional handlebar stem, loosen the bolt on the top of the handlebar stem a couple of turns, tap the bolt with a hammer.
The bolt should drop down, at this point the bars should be loose.
Do not raise the handle bars above the safe limit line as the stem could break of come out .
Once you have them where you need them, re-tighten the bolt.
Hope this is of some help.
Ed
Anonymous
  • 34 Answers
  • Posted on Jul 18, 2009
SOURCE: Can I raise the handlebars on my Marin hybrid bike
Most likely you have a threadless headset on your Marin which means you can not raise the handlebars without replacing the stem or handlebars themselves. In addition, many times you will also have to replace some of the cables and housing because they will be too short once the handlesbars are raised.
If you do not have a treadless headset than raising your handlebars is very simple. First check to see what type of headset you have. A threadless system with have a allen head on the very top of the stem and one or two more allen head bolts on the side of the stem. The threaded system will usually have only one bolt on the very top of the stem. It is sometimes covered by some type of cap. Also on threaded headsets, there will be a large nut under the stem, which is what most people mistakenly loosen to adjust the stem. Do not touch this nut, it will adjust the headset. Same goes for the allen head on the treadless headset, it will also adjust the headset so don't touch it.
So if you have a threaded stem, simply loosen the allen head or nut on the top of the stem and raise the stem up. Make sure you do not go above the max line and that you are still able to turn the handlebars freely.
Hope this helps. If you need any more help you can connect me at [email protected]. Thank you
Anonymous
  • 843 Answers
  • Posted on Jun 24, 2010
SOURCE: How can I raise handlebars on a 26 in. Mountain
You need an Allen wrench (a.k.a. hex key) to fit the bolt head right in the middle of the handle bars. Loosen this bolt just 2 or 3 turns then tap the head with a soft hammer or block of wood and a hammer. Then pull the handle bar stem up (and all of the way out so you can see how the wedge-shaped nut at the bottom of the stem works). Look for a mark on the stem telling you how high you can safely raise the bars (you have to leave enough of the stem inside the tube so that it will be strong.) Put it back in and tighten it up. If you found this helpful, please vote. Good luck
Mike
  • 4383 Answers
  • Posted on Oct 30, 2010
SOURCE: how do i raise up
Usually, there is a bolt in the center of the stem assembly, you crank it counter clockwise 2 to 4 turns and tehn tap it with a hammer. This releases the wedge and you can move the assembly up. There is an upper limit marked on the stem, be lower than that.
Testimonial: "thanks, i thought that bolt had something to do with it. just bought this bike a few days ago and i'm very happy with it"
Can the handlebar be raised on a 2015 giant anthem 1
The seat should typically be at a point such that your knee has a slight bend at the bottom of the pedal stroke. The handlebars go wherever they are most comfortable for you. Reach (horizontal distance) is adjusted with a different stem. Height on your bike can only be increased by using a stem raiser. The following Google search will show you what is available, and the video results will show the procedure to install it.
2answers
Adjust handlebar height on Schwinn Varsity
I'm answering 7 years later. I have a Schwinn Varsity 2500 Bike made probably in 2015. The Schwinn Varsity Bike is not set up the same way as a traditional bike. I loosened the center compression bolt and the two side stem clamp bolts and it came loose where I can adjust it up or down but, there's nothing to tighten the slack up below. I did some research. My original post here was to add or remove a spacer. I think you can remove a spacer to lower but, I don't think the stem is long enough to add another one. I've seen they sell an extension that you can add-on to make the handle bars higher.
I have a men's Cross-Fit bike from the 90's. How do I raise the handlebars?
A major limitation is the steerer tube length. No matter how many times you cut a steerer tube it won't get longer.
Getting Riser Bars or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best and least-invasive option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
If you had purchased the bike at a reputable Bicycle Shop they would have fit the bike to you before you took it home.
Aug 06, 2011 • Cycling
1helpful
I do not know how to raise the handlebars for my lamborghini toro mountain bike can you please help?
http://www.sheldonbrown.com/handsup.html
When one purchases a bike at a reputable Bicycle Shop they will fit the bike to you before you take it home.
1helpful
Just bought a Mongoose Spear (26"). How do I raise the handlebars?
Getting Riser Bars or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
I would recommend you get used to the position that yields a careful compromise between aerodynamics and uprightness when needed.
Why does bike size is important?
It is clear that wearing a shirt two sizes too small would be uncomfortable, and wearing a shirt two sizes too large wouldn't be good either. In the same way, riding a wrong size bike will fit badly and make you uncomfortable, too. There are two main problems, one obvious and one a little more subtle.
The first big problem with a bike that doesn't fit is saddle height. You need the saddle to be just high enough to give your legs the right extension when you pedal. Too low and your legs stay bent too much all the way around; this doesn't use your leg muscles well and you wear out quickly. Too high and you rock back and forth on the saddle as you pedal, very uncomfortable. Either extreme (too high or too low) can also be very hard on your knees.
Saddle height is adjustable, of course, and if the bike frame is at least close to the right size, you'll be able to adjust the saddle to the proper height. If the frame is a lot too small, you can usually overcome this problem by buying a longer seatpost to move the saddle back up to where you want it. (But that causes other problems we'll talk about soon.) If the frame is much too large, you won't be able to drop the seat far enough to be usable, and there is no practical way around that problem.
The saddle on a bike can be adjusted up and down several inches, even as much as a foot if you consider replacing the original seatpost with a longer one. But the handlebars can't be moved nearly as far as saddles can. Most handlebars can be adjusted up and down or forward and back only two inches or so, and even this small change is often a complicated operation of replacing parts, not just loosening a few bolts.
This can lead to all sorts of problems. If the handlebar is too far away from the saddle, you have to bend down further and reach far out to grab the bars. This puts more weight on your back, arms and hands, which is uncomfortable. Having the handlebar too close to the saddle is less of a problem, but in extreme cases it can cause your knees to bump the handlebars when you are standing up to climb a hill. Having the handlebar a lot lower than the saddle is similar to having it too far away-you have to bend far over and reach further to grab the bars, an uncomfortable position. Having the handlebars high up is not a big problem, except that sitting upright slows you down. Your legs aren't as strong when you are sitting up, and that position causes more wind resistance when riding fast or into a wind.
Bike size has a big effect on handlebar position. If the frame is too small, you'll have to push the seat up high to fit your legs. You won't be able to move the handlebar up as much, so it will be a long reach back down to grab the bars, and your back will be quite bent over. If on the other hand the frame is too large, the bars will be up high but might be too far forward (since the frame gets longer as well as taller).
Dec 21, 2010 • Cycling
What size should I get?
A bike is the right size when your child can:
•Sit on the saddle and rest the balls of both feet on the ground.
•Straddle the top bar with a comfortable clearance and with both feet flat on the ground.
•Reach the handlebars with a slight bend in the arms when sitting on the seat. If there are handbrakes, your child should be able to grasp them and apply enough pressure to stop the bike.
•ByK bikes have more knee room than other bikes, which helps to lengthen the life of the bike and make the bike handle in a more predictable way.
As your child grows, you can raise the seat post and handlebar stem according to the owners manual limits.
Dec 16, 2010 • Cycling
Top Lamborghini Cycling Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Tony Parsons
Tony Parsons
Are you a Lamborghini Cycling Expert? Answer questions, earn points and help others
