According to the specifications the camera has both an in-built mmory, and also accepts an SD card with a maximum of 512 MB . Maybe it will accept a larger SD memory card but only record up to 512 MB? I do not know.
SD cards are common in camera stores, but these days they make them with 1, 2, 3 or even 8 GB ( 1GB about 1000 MB) !
To format a microSD memory card follow the steps below:
You may need to format the memory card with your Nokia device.
However, all data in the memory card is permanently deleted if you format the memory card.
It is recommended to back up device memory regularly to the memory card. The information can be restored to your device
later.
To back up information from device memory to a memory card, select Menu > Tools > Memory card > Options > Backup
phone mem.
To restore information from the memory card to the device memory, select Menu > Tools > Memory card >
Options > Restore from card.
Do not remove a memory card when the card is being accessed. Removing the card in the middle of an operation may damage
the memory card as well as the device, and data stored on the card may be corrupted.
If you cannot use a memory card in your device, you may have the wrong type of memory card, the card may not be formatted
for your device, or the card has a corrupted file system.
Tip: You can install and remove a memory card without removing the battery or powering off the device.
