GPS Logo
Posted on Dec 24, 2010
Navman My50T - screen has frozen, can't get any other screen apart from initial start-up screen (except for screen showing connected to computer when connected by usb).
Anonymous
Level 1:
New Friend:
  • Contributor 8 Answers
  • Posted on Jan 19, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
8
Questions
0
Helped
9455
Points
42
Had a similar problem with a MY60T.
Spoke to Navman support.
1. Connect your unit to the computer.
2. Use windows explorer to go to the Navman folder
3. Go to the database folder.
4. Delete "Database.db"
5. Switch off & re-start you unit. The databse file is re-created on startup
  • 3 more comments
  • the_earl2000 May 27, 2011
    I had this problem and followed the steps above and now it's working fine! Thanks!
  • Anonymous Jan 19, 2012
    thanx mate, it really helped me out, cheers...
  • ladyeliza428
    ladyeliza428 Jul 05, 2012
    OMG!!! thank you so much this was a life saver....i thought i would have to buy a whole new unit ...used on my MY60T Bless you and once again your info was a life saver ...thank you :)
  • Anonymous Oct 14, 2012
    I have a Navman MY-50T and the startup screen will not go away, I tried connecting it to the computer but it does not register??? What can I do.
  • Anonymous Feb 02, 2013
    Can't find database in navman foler
I have lost MY50T users manual need to download
You can download Navman MY50T user manual from here
Jun 21, 2010 • GPS
5helpful
Screen is frozen, can be turned on and off but wont go passed initial stage
1. Connect Navman GPS to PC viamini-usb cable. 2. Go to 'Start' 3. Go to 'My Computer' 4. Open the 'Navman' folder 5. Open the 'Database' folder 6. Delete the following file only- 'dababase.db' 7. Close the folders 8. Disconnect the mini-USB cablethen restart the Navman GPS by sliding the switch to 'Restart' then back to'On' after 10 seconds. The unit shouldstart & the database.db file will be re-generated automatically.
Downloading speed camera POI to a navman MY50T
check with supplier even though you have the app some models are not compatible.. my tomtom is the same
May 14, 2010 • GPS
Cannot get lane assist to work can you [please advise how to print manual for navman my50t
Go here:
http://www.navman.com/in-car/3294/Australia/Navman-Australia/Our-Products/NEW-MY-Series/Navman-MY-50T/
and click on the tab labeled "user guide". This will download the user's manual. Then, save to your computer and print it if you want. Manual is VERY long (90 pages)
I cannot find a hardwere manuarl for the
I found that the hardwere manuarl for the my50t is on the navDesk application installer disk.This Disk is supplied with the Navman my50t
GPS. Thank you for your reply.
Jan 02, 2010 • GPS
6helpful
Navman s80 frozen
just been on navman site,in tech surport it said hold on/off button down for 10seconds to reset.
im glad to say it works
Navman iCN 550 GPS frozen on start up screen and makes a noise like it is stuck
Try hitting your reset button if you haven't already. I had the same problem and this worked for me.
Top GPS Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a GPS Expert? Answer questions, earn points and help others
