E247 The software counter memory PCB and the software counter value stored in SRAM are found inconsistent are you try to adjust the machine counter reading? That is Canon security features you cannot adjust counter by replacing soft counter board
First I will try to re- install software, that is all to your hard disk. Most probably you need to change the hard disk and then re install software..Most common causes of hard disk failures due to power cuts.
You have to have the telugu fonts installed in the machine otherwise, the other work around, you have to make the Canon print as an image and not as a text.
