Canon LASER SHOT LBP-2900 Printer Logo
Anonymous Posted on Dec 24, 2010
How do I check if I have marks on the drum of my Canon Laser Printer (LBP2900B)?
  • Anonymous Dec 26, 2010
    Thank you for your help. I measured the distance between the marks and found that the marks are approx. 4cm or 40 mm apart. Referring to your list, the figure closest to that is 38. That means I have marks on the Primary Charging Roller. Could you please further tell me how do I locate Primary Charging Roller and go about fixing it.
Anonymous
Level 2:
Scholar:
  • Expert 78 Answers
  • Posted on Dec 24, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
78
Questions
0
Helped
42731
Points
286
If you have marks on your drum there would be repetitive marks every 76mm.
Interval (mm; approx) Roller or component
55 Feed roller
46 Transer charging roller
38 Primary charging roller
76 Photosensitive drum
31 Developping cylinder
57 Fixing film unit
56 Pressure roller
Testimonial: "Thank you for your help. I measured the distance between the marks and found that the marks are approx. 4cm or 40 mm apart. Referring to your list, the figure closest to that is 38. That means I have marks on the Primary Charging Roller. Could you please further tell me how do I locate Primary Charging Roller and go about fixing it."
    The primary charging roller is an internal part of the toner cartridge.
    unless you want to repair/rebuild the cartridge yourself I'd suggest just replacing it.
3answers
Canon lbp2900b driversoftware donwload
Hi, To download the driver for your scanner just visit cannon website. Search the compatible driver for your printer with your printer model and download it easily.
3helpful
Canon Laser Shot LBP2900B Printer have 300 dpi
27helpful
3answers
how to print 300 dpi in Canon LBP2900B Laser printer
5helpful
2answers
I wish to install a Canon LBP2900B printer under windows 7. I have downloaded the drivers from Canon but the windows system adds the printer as 'unspecified' not as a printer. It is connected by a usb...
somehow this is because Win 7 actually does not support all devices. try installing the device using win xp or vista, if it does work then it really has no support for win 7
2answers
We have canon LBP2900B printer. printer margin is printing in black please help out thank you
you have to clean the developer speciali if they are straight lines...also see if it has wheels on the sides they are probably covered with tonner
17helpful
2answers
How to refilling toner in canon lbp2900b
it a very easy to refill the 12 A tonner
remove the drum from cartriage then find 2 hook fixed the cartriage just relese it you find your cartriage divided in to 2 parts relese the nut from other side of the cartriage open the cap then fill with the tonner fix all
After inserting tonner printer makeing noise
May be the drum is tight with cleaning blade. Please check it.
6helpful
2answers
old marine
old marine
ZJ Limited
ZJ Limited
