Question about Necchi 6015 Mechanical Sewing Machine
I have an Necchi and omega sewing machine the model is 6022. I need a bobbin case that holds the bobbin in it and the owners manuel can you tell me the price of each one of them
  • 25 Answers
Go to http://allynint.com/
Get the phone number off the web and call them, they have what you need.
If you speak to Dorothy, or Bob Coen, tell them Merry Christmas from Ellen in Arizona. Merry Christmas to you too,
Posted on Dec 24, 2010
SOURCE:
I have a Necchi Omega 6147. How can I adjust the drop-in bobbin to use upholstery thread to sew heavy fabrics or leather?
You would need to adjust the tension screw so the tension is looser than usual. However, remember to mark the setting BEFORE making any adjustments so you will know where to return the original setting.
Bobbin Tension How and Why Tension is Adjusted
Understanding Bobbin Tension
Understanding Thread Tension Threads
Feb 10, 2017 | Necchi Sewing Machines
I cant get the tention right what numbers should the 3 knobs be ever three or 4 stitchs are slack or all of them i dont no what knob is for the top stitchs and which is the under neath
Forget the three knobs for tension adjustment, only the top tension knob should be about 4 or 5, you should be able to pull the bottom thread through on the bobbin with slight resistence, if it is too tight slacken the screw on the bobbin case anti clockwise about a quarter of a turn, pattern selectors stitch length and width work independently of the tensions.
Aug 10, 2011 | Necchi 6022 Sewing Machine
Need an insruction manual for Necchi model 6022 how can I get one or where can I get one? Thanks
Call 1-800-525-9987 x 20 and ask for Bob.
We have them in stock, $14.25 incl. shipping.
Jan 06, 2011 | Necchi 6022 Sewing Machine
I have a necchi sewing machine. How and where do you insert the bobbin in model 525fa
if you have a snap in sewing table remove it first
at the bottom in front of the needle plate area is a bobbin case door
when you open it there is the bobbin case & also should be the feed dogs
always keep the bobbin area clean of lint or loose threads
take note of how the bobbin case is inserted in the bobbin area,, see where the thread tail is at on the bobbin case
then make sure the bobbin is wound correctly or it can cause sewing problems
reinsert the bobbin into the bobbin case the same way it's removed
I also have a necchi sewing machine, the base of your is like the base of mine, if you need a picture of inserting the bobbin,, send me a comment with your email address & I will send you a picture of the threading the bobbin case & inserting it
Nov 17, 2010 | Necchi 3101 Mechanical Sewing Machine
Top thread too loose, brings up bobbin thread. Tried to adjust, but cant get it right. Have manuel, but cannot locate it currently I have The Omega model
Hi. If the bobbin thread is coming up on top, then the upper tension is too tight. Try loosening it.
Hi. The best way to adjust your tension is to use good-quality thread, a size 12 needle, and different color threads in the bobbin and on top. That way, it's easier to see which thread is loose. Sew a few inches, check, and adjust (make sure the pressure foot is DOWN). Stitch a few more inches, recheck, and adjust some more. Just move the adjustment knob a little bit each time.
You might also want to use a bit of unwaxed dental floss and floss the tension disks. That helps get rid of any old lint and pieces of thread that build up in there.
As a last resort, you might need to adjust your bobbin tension. There is a very small screw on the bobbin case that tightens/loosens the spring/lever. If you need to adjust it, only move the screw a tiny bit. But, like I said, this is only a last resort--almost all adjustments can be done by adjusting the upper tension.
Hope this helps!
Robbie
Aug 12, 2010 | Necchi 6015 Mechanical Sewing Machine
Bobbin case on my 524fb necchi has come apart
Almost all Necchi use a class 15 bobbin & bobbin case, a new case should cost around 7 to 10 dollars!
Dwayne
Dec 02, 2008 | Necchi 3537 Mechanical Sewing Machine
6022 necchi sewing machine
There is a site that has instructions with how to thread the machine properly. Click here for the www.sewusa.com threading section
Nov 03, 2007 | Necchi 3537 Mechanical Sewing Machine
Necchi 6015 Mechanical Sewing Machine Logo
156 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
