You have an issue. The part number you gave is for a 12V power supply for an external hard drive. Since a typical USB puts out 5V, it cannot possibly drive your hard drive. There is a possibly..albeit low...where you can get a plug that plugs into 2 USB ports and provide 10V but I am not sure that will be enough to drive it. If this external unit is already in a case, look for a plug that would accept the power supply pin (pix attached)
Semper Fi,
Z
SOURCE: How do I format a Seagate 500 to work on a Mac?
I bought one of the Seagate FreeAgent 500 devices yesterday and followed the instructions on the back of the box: plug it in; let the Mac recognize it; go to the Disk Utility function (found in Applications > Utilities); select the Erase tab and check the box to re-format the FreeAgent to Mac OS Extended (Journaled) and choose a name for it. Then proceed with the re-formatting. It took only a few minutes but as soon as it was done, Time Machine (Leopard) kicked in and asked if I wanted it as my backup drive. I said yes, and away it went. Hope this helps. By NewbieMacUserSept2007
SOURCE: I cannot see my free agent external drive
Thanks for your responses...
I've pretty much decided that it must be a hardware problem within the harddrive itself...Can anyone lead me in the right direction to maybe take out the harddrive to put into another external shell in order to hopefully recover my data? Again I'm using a Seagate Freeagent Desktop 500GB external harddrive.
SOURCE: How to format my new seagate freeagent 500 gb with macbook?
Here is a link to Seagate that describes how to fromat your drive fro a Mac. GOOD LUCK!
SOURCE: I bought a seagate 500 But I don't know how to put pictures on it
Yes. Its possible.
Please rate the answer if you feel that this solution solved your issue.
Thanks for contacting Fixya!
Step 10
Shut down the computer and disconnect the external hard drive. You can now use the external hard drive to boot up another computer using the installed copy of the Windows operating system.
https://www.techpowerup.com/forums/threa...
Last resort is to remove the drive from the enclosure, and find another way to connect it to a computer. There are devices that connect an external hard drive to a computer without the case.
Example:https://www.amazon.com/Mosuch-Adapter-Co...
