My son receive a Christmas present a remote control car and it doesn\'t turn....... I emailed the [email protected] 12 days ago and they have not responded...... this is a crappy way to do business
SOURCE: propel rc execuheli upper rotor
I had the same trouble this morning, I used the screwdriver that is supplied and removed the right side of the body. I found the gear on the motor shaft had slipped up the shaft and was not meshing with the bottom rotor gear. slide the motor gear down into postion, and install the right side of the body.
SOURCE: new bright 19.2v nicd battery problem
Don't throw away any NiCd power tool battery, Firestorm or Versapakbattery that does not hold a charge or does not give you the power youneed, you can get new life from your battery or device that containsNiCd batteries. icad batteries often die in such a way that they won't take a chargeand have zero voltage. This usually means they are shorted out bycrystal dendrite growth. You Can fix these shorted crystal dendrites by"Revitalization through Vaporization of Dendrites (RVD) Process".
You can get this guide from here
SOURCE: Can not find website to
Go to the home page at:
http://unclemilton.com/
Here is the Ant Farm page:
http://unclemilton.com/ant_farm/
Hope that gets you going. Please take a moment to rate this solution.
Thanks for using Fixya.
