SOURCE: FRIGIDAIRE STOVE
F1 is a EOC (electronic Oven Control) failure... you will need to repace EOC
SOURCE: Frigidaire self clean oven: how long will it stay
you can set the amount of time for self clean that you want, you can also turn it off during mid cycle, but if oven is hot it will not unlock the door til it is cooled down enough, maybe 20 min to 1/2 hr. It is a safety pre-caution.
Hi mannycarla - Typically error code F1 indicates that the range has detected an issue with the runaway temperature (overheating). A certified technician will need to check the RTD senor probe and/or EOC and replace if necessary. Meanwhile try reprogramming the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart range. Usually this will clear most false error codes. If it proves to be ineffective, contact a professional to move forward accurately.
