Electric Mobility Invacare Pronto M41 Electric Scooter Power Wheelchair Logo
paul pecou Posted on Dec 23, 2010
Wwe have a pronto m41 mobility chair.the service indicator light is telling me its a right brake problem can i fix this and how. also the led lights are chasing left to right. i have to get this working please help
gnsdance97
Level 1:
New Friend:
  • Contributor 68 Answers
  • Posted on Apr 30, 2011
gnsdance97
Contributor
Level 1:
New Friend:
Answers
68
Questions
0
Helped
36714
Points
82
First thing you must know is that the error codes are reversed on Pronto chairs with SPJ+ joysticks.
Only one year the M41 was made that the codes were correct. From approximately April 2008 to May 2009 was the only time a left error code ment left motor and a right code ment a right motor. Same for brake codes.
Brakes codes happen when the brake is out of gear, unplugged from the control brain or wire cut. Also from internal coil damage. Unless it's a wire you can reconnect you cannot fix the brake.
Pronto M41 Chair. What does the little yellow wrench error mean?
It means there is a fault. You count the number of times it flashes and that tells you the error.
https://www.google.com/search?q=pronto+m41+flashing+wrench
Installed new batteries Service Indicator Light flashing 5x Manual says problem is with Left Park Brake and says check L P B connections. How?
There is a lever on both sides of the chair they are there to make it easy to push the chair without power. both sides need to be in brake mode in order for the chair to operate. If the levers are locked in brake mode then the motor wiring will need to be checked that it is plugged into the controller. A Tech may need to be contacted to help with this.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Unlock a spj+ joystick on a pronto m41
Lets make sure this is just the joystick lock mode. When you turn the chair on and it is in joystick lock mode all the battery level lights will chase across several times and then the joystick will turn off.
When you turn the chair on and you see the battery level lights chasing from right to left push and hold down the power button till the lights turn off. Only the first year that the M41 was made had this option.
1helpful
My M41 invacare controller keeps flashing and it flashes 5 times. I don't understand what the fix for this.
If your M41 has the mark V controller that is seen pictured in the stock photo you provided, the 5 flash code is a left park brake fault.
1. Turn off the chair.
2.Disengage the left motor (levers are located in front under the seat) roll the chair back and forth and re-engage the left motor.
3. Engage the left motor.
4. Turn on chair.
If you happen to have the older Mark IV controller (has a toggle switch to turn on/off and three battery lights), the 5 flash code means the chair is receiving high or low voltage from the batteries. I would recommend having the batteries checked.
If the chair stops flashing, you are good to go. If the chair is still flashing, you will need to contact a technician to possibly replace the left brake. I recommend Repair Xpress FixMyPWC com Nationwide service and delivery solution for power...
What does a yellow wrench indicator light mean on a Pronto M41 w/Sure Step?
The yellow wrench is a diagnostic tool. How many times does it blink between pauses. Example might be 3 blinks then pause then 3 blinks then pause, over and over. Hoe many does your chair blink?
3helpful
I have an Invacare Pronto M41. When you push the power button, the battery meter lights ramp up from left to right, then go off, then ramp left to right, go off, continuosly. Also, the service light is...
mad check the freewheel levers under the front of the seat on the base make sure that they are in the drive mode turn the chair on and you should be good to go. Have the power off move the levers back and forth and leave in the drive mode then turn the power on and you should see normal lights and operation Hope this helps
We are trying to move the chair and the service light keeps coming on
The service light indicates a problem. Count the number of flashes. ie flashes 4 times pauses flashes 4 times etc. If you have the owners manual the flash code section will tell you what the number of flashes mean: 3 flashes left motor 4 flashes right motor. You will have to contact a service company to repair the chair once you find out what flash code you have. If Medicare pirchaed the chair then they will pay for most of the repair cost. Hope this helps
Full set returns once then reverses and comes back grteen orange trd seven time and beeps and stops
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Chair fully charged but quit running without for "no reason"
Are there any blinking lights? The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
Check all of your connections to ensure nothing has come loose. Ensure your batteries are not damaged and fully charged and that the fuses are good. If a power chair has been stored for a while the charger may indicate a full charge but the batteries are full of oxidized crud instead of power and need to be replaced.
Power button is turned on an it just blinks, and nothing works. The chair is a bruno.
Top Electric Mobility Health & Beauty Experts
Rob Hill
Rob Hill
ZJ Limited
ZJ Limited
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
