Ok all mine had the same problem however problem has been solved! The power cord that plugs into the charger is a common cord you may have laying around the house. I switched the power cord to my charger and the dreaded blinking stopped! Its just a bad power cord to the charging unit! Hope this helps!
The lithium-ion battery is only enough for one day, needs to be recharged very often. Much better use a camera with regular AA batteries if you don't take pictures very often. The charger light turns off when the contact is bad. Try using a different outlet.
