SOURCE: Keeps going to quit screen
it could be that someone pushed the button in too hard and it wont pop back up because even if you lightly touch it, it could go to that screen
SOURCE: PSP no power
Ms Piggy....
It sounds like your PSP is "bricked". Have you upgraded the firmware or added custom firmware? If so, you'll need a Pandoras battery/memory card to repair. Try ebay for those.
Good luck
SOURCE: PSP turned on, black screen, cannot access recovery menu
Your psp screen may have broke you can buy a repair or get it fixed at ebay.com.Type in psp repair and you will see people will fix them for a low cost.
SOURCE: reset psp,once turned on doesnt work?.
Looks like you might of run an update of some sort from the UMD disc or memory card. Take the battery out and then put it back after 15 mins.
If it still doesnt work im afraid you may of bricked it by forcing shutdown on the PSP.
There are people on ebay who might be able to help if you cant get the PSP to work.
Just type 'bricked psp' into search and tell the person what happened. It shouldnt cost more than £15 to sort the PSP out.
SOURCE: my psp has no sound from headphones and speakers
my psp go don't have sound on the speaker. But still can listen with earphone. how to solve
Hi Gohan102,
Open the battery compartment, and remove the battery. Look at the bottom inside corner for a little square sticker with has marks on it. is it dark or light, If it is dark, your PSP has come in contact with moisture. I suspect that your PSP has gotten wet or damp. If the sticker is dark, you need to keep your battery out for about 2 days, and keep the UMD door open and the whole PSP kept in a dry environment. Try it after 2 days of drying to see if it is recovered. Good luck Gohan....
