Linksys Bundle: BEFW11S4 802.11b Wireless Router/Switch + WPC11 PC Card (BEFW11S4 + WPC11) Logo
Posted on Dec 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want to add a LINKSYS workgroup switch EZXS55W behind my wireless routher LINKSYS BEFW11S4 v2 via uplink cable connection. When hardwiring my anything to the switch port 1-4 does not get internet access
Anonymous
Level 2:
Scholar:
  • Expert 124 Answers
  • Posted on Dec 23, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
124
Questions
0
Helped
44699
Points
261
Are those 4 ports in different Vlan ?
If you connect your wireless access point to the 1st port are you able to access the internet through 2nd port or 3rd port ?
Are the ports 1-4 admin down ?
Will the 5-port linksys workgroup work on my ps3? i have been using a wireless linksys for over 5yrs now and i think it finally broken. comcast said that they are seeing and great signal coming from my...
try down powering your router for 30 seconds and turn it back on.
on a p.c connected to the wi fi. go to the command promt and type in tracert www.fixya.com
and see if the path takes you to your router ip address .
1helpful
I have a Linksys 5-port switch connected to a cox cable modem and I'm trying to use it to connect two computers at the same time. Only one works at a time and I have to reset the switch and modem to get...
Because the cox cable modem will only bind to one mac address (computer). You need to purchase a router, any router linksys, dlink, will do, get a wireless one so you can setup wifi as well. Plug your cox cable modem into the wan port on the router, plug your pc into one of the ethernet switch ports, you can use your web browser IE to login to the router and secure your wifi signal, power cycle your modem to make it bind to the new router. Most linksys dlink are programmed for a class c network, you could in theory put 254 devices, computers on your connection now.
I'm having problems with my Linksys ezxs55w switcher. The plugs are not lined up with the correct lights. For example, I plug the uplink into the uplink plug, but it shows up as number 5. Same with other...
You have a 5-port router. The 5th port can be used either as an "uplink" port (with a cross-over Ethernet cable) or as a "data" port (with a straight-though Ethernet cable).
You've not provided enough details to trouble-shoot the "staying online" problem, i.e., IP-addresses of each of the connected computers/printers, whether you're using CAT3 or CAT5 or CAT5E cables, whether you've tried different Ethernet cables, and whether the router is connected into a UPS that provides "smooth" power.
Can u help me retrieve my wifi password?
You need to do a factory reset of your wireless router. This should clear the password in it. There is no password for your 5-port switch.
I have my internet through my cable company and i want two com hooked up but are not going to have them online at the same time so can i use the 10/100 5-port model#EZXs55w by using the line coming out of...
Hello Friend
You could definately use Network Switch-10/100 5-port model#EZXs55w to Connect to Network Router or Modem using Uplink Port at back Panel of 10/100 5-port model#EZXs55w Switch.
Simply Connect Modem cable to Uplink Port of Switch and connect computers to other 2 ports of switch. Allow computers to get Automatic ip addresses..if computers still not getting ip addresses auto--contact cable company and config your cable modem to use NAT or enable NAT--
Can't get two computes to run internet at the same time
If you login to your router and make sure DCHP is enabled, and then go to Services (services.msc) on your computers and make sure that the DCHP Client is running, it'll automatically assign IP addresses for your computers and they'll both connect okay.
Hope this helps
Chris (ziraffa)
2answers
EZXS55W 5-Port Workgroup Switch
This is a wired network switch your inquiring about. Is this plugged into a wireless router?
If so what brand is the router.
ENET Port issue on BEFW11S4 Wireless Router
Hi!
Try these steps:
1. Make sure the wireless is disabled when you're doing that. It might cause a confusion between the wired and wireless connection.
2. Try to plug it at other ports (1-4)
3. Try another known working ethernet or CAT-5 cable.
4. Set the laptop's LAN card's speed to 10-hald duplex.
Try these and hope it will help you ;-)
Linksys BEFW11S4 upgrade problem
hi,
Download the TFTP---set up file for BEFSR41 v2 and also download the latest firmware of ur router.
Double click on the TFTP file and connect to the router using the default gateway address (192.168.1.1_ and upload the latest firmware....before that do a hard reset for the router foe one minute.
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
