There are two ways in which you can add a playlist....
1......by using your playlist via the player...
2......or by creating one using the computer....
First lets see the one using the player...all you have to do is go to the song navigate option...highligh the song that you wan to add to your playlist and then click the record button.you will be given two choices..one add to my playlist and two erase.....click the add to my playlist option and you will have the song added to you r playlist.....
second method is create a normal playlist using windows media player with the correct directories in the player and then copy the file to the player...
now when you press the menu button for a second or two in the songs menu...you will be displayed two choices....one file navigator and the other is playlists....
click the playlists option to access the playlists....
Menu-Audio
player--Playlists-Create playlist--Now create playlist as you want-Now select
same playlist which you have created-Options-Add-Now if you want to add single
song, please click on song name and song will be added-if you want to add
multiple song, then select "Multi" option from left side of the bottom-Mark the
multi songs -Now press "Done" from left side of the bottom-Now select the first
option of "Play" to play songs of playlist.
Mayank Purohit
