The beep code will begin with 10 very fast beeps, followed by 5 slower beeps. The 5 slower beeps is your actual code. The beep code 5 is a brake fault.
The scooter may be in freewheel mode or there may be a short in the brake.
Make sure the scooter is in drive mode with the rear brake lever in the correct position. If that does not clear the fault you need to check the electromagnetic brake.
To check the brake you need a digital voltmeter. The brake should read 30 to 65 ohms when you read across the pins. You need to measure the resistance at each successive point on the harness because there are 5 connectors. While you are inspecting these plugs, check for corrosion, loose pins, broken wires, and pins not making good contact. Disassemble the front and rear halves of the scooter when you do this.
If all the resistance checks are good up to the controller plug for the brake, you have a bad controller. With that being said, I usually see a bad connection at the multiple points in-between. Sometimes the wires for the brake will melt at the connector at the controller.
Inspect these areas visually, removing the rear cover of the brake/motor/transaxle and the controller. An experienced tech should charge you under 1 hour labor for the diagnosis. You may be able to save some money by checking the obvious areas for unplugged or bad connections first.
The brake will cost about $250, the interface wiring and connectors about $50 and the controller is about $500. For this reason, you should invest in a good tech to diagnose the problem first, before proceeding with any hit and miss do it yourself repairs.
Including a second visit to install the new parts, labor cost should not exceed 2 hours total.
This is a very popular model so you should be able to find an experienced tech in your area.
Testimonial: "Awesome detailed info on how to fis/diagnose the problem."
Put the lever under the seat on lock and try to drive it...it should go
turn off key first...then put on lock and then turn on key and try to drive
Are there any detail diagrams for this "fix". My Mother-in-law bought this scooter new, it sat for years, bought new batteries and now get the 10/5 beep code. It's never been run more than two or three times. She has now passed. Warranty is gone as is the company that sold it to her. Would like to fix and sell, not put any more money into it (had to buy new batteries). Thnx
