Question about Sony Ericsson K618i Cellular Phone
"Charging error: Stop charging!"
    President:
  • 782 Answers
Sir please give to the sonyericsson service center to change the charging jack of the phone and they will check the battery status of the phone.for charging in a normal condition
Posted on Dec 23, 2010
SOURCE:
My sony ericsson k800i does not charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Aug 20, 2012 | Cell Phones
My W810i Phone charging sometimes stops suddenly while charging , tried master reset,its not affected ,please advise Thanks vish
Please check that your charging terminal is free from any fungus type material.Due to excess use carbon builds up on the terminal. Use any old toothbrush to clean it. If this is not the problem then change your charger.
Sep 15, 2011 | Sony Ericsson Walkman W810i Cellular Phone
My w850i is not charging when i plug in the charging mobileis hit
Check the following two things carefully:
1. is your charger working properly?(It may be found faulty)
2. is the charging port OK?
If you say that your mobile shows charging in start, and after few minutes it gives an error "charging error stop charging". Then you should confirm first that its charger is original or not. If it is not a original charger, then you should change it...Good luck :p otherwise go to mobile repairing shop.
Sep 09, 2011 | Sony Ericsson W850i Cellular Phone
W810i not charging
basicly there are 3 pins on the top of your phone (take the battry out and you shall see them on the far end) get a pair of tweezers and push the clips in and hold for a while ... slot your battrey back in and put it in charge it should work :)
Jun 28, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Sony Ericsson W850I
Most new phones allow charging with the USB cable. With some phones, you also have the option to select whether you want to allow USB charging. If you're trying to charge with USB, make sure that your phone supports USB charging and that the option is switched on.All the best!
Happy to help
Have a nice day!
tc
Jun 05, 2008 | Sony Ericsson W850i Cellular Phone
Battery Charging Error - Disconnect Now error message
Most new phones allow charging with the USB cable. With some phones, you also have the option to select whether you want to allow USB charging. If you're trying to charge with USB, make sure that your phone supports USB charging and that the option is switched on. please check ur settings..All the best
Happy to help
Have a nice day!
tc
May 30, 2008 | Sony Ericsson W850i Cellular Phone
My new sony ericson w850i is having to be charged every other day even though sometimes I haven't used it for more than 1 or 2 text messages,when I plug the charger in (the one that came with it in the...
optimise charging means that it is charging.. try leaving it to charge for an hour or two. if it still doesn't work, then you bring it to a service center.
Apr 27, 2008 | Cell Phones
My phone wont turn on anymore
have your fon reformat.. you have a software problem...
Oct 28, 2007 | Sony Ericsson Walkman W810i Cellular Phone
Sony Ericsson K618i Cellular Phone Logo
458 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Ekse
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
