JVC TH-M606 System Logo
Posted on Jul 04, 2008
I am missing some parts
I WAS WONDERING IF U GUY CAN SELL ME THE JVC HOME THEATRE SYSTEM REMOTE CONTROL AND THE WIRE THAT CONNECTS FROM THE SUB TO THE DVD CHANGER IT IS LOCATED BEHIND THE SUB
  • kristopherle Dec 24, 2008
    looking for a remote control for the jvc th-m606 system, all the websites i find on the web want almost $40, does anyone have a spare or know of any more reasonable website to get remotes?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 02, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
293
Points
How can I get the cord that goes from the DVD player/CD player to the subwoofer?
Anonymous
Level 1:
  • Posted on Dec 23, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
293
Points
I have jvc tha5 home theatre,and the audio is completly dead,only pictures can be veiwed.can you recommend jvc service station in mumbai
Anonymous
Level 1:
  • Posted on Jul 19, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
293
Points
Jvc home theatre system cable that connects the the bub and the dvd
I lost my remote control, how do I get another one?
On the off-chance try e-bay... I had a miss functioning remote control on a kenwood home theatre system, searched everywhere for a replacement, then tried e-bay.. Chanced on someone who had found a remote control of the same model after selling their system (I was amazed by the coincidence), worth trying.
My bass powered subwoofer on JVC system doesn't turn on
You need to check the signal. If there is not signal present or the volume is low the sub will not turn on and goes in to sleep mode.
-david
Connected home theatre system but no sound sub woofer
If the system uses a remote control, you may need to adjust the subwoofer out signal setting or turn on the sub in a menu, and on many systems, you can only access those settings via a remote control (you should check the onkyo user manual on how to do it).
Now, this is just one suggestion, it may work, but then again, it may not.
These could also be connection problems or some internal trouble in the onkyo sub signal output section or in the subwoofer input section, but hopefuly, it's just a "turn on" or "signal level" setting in a menu.
Good luck
3rq8 (triarcuate)
Have an existing ts-1100 home theatre infinity speakers
You cannot use this system with one that does not have a Subwoofer or LFE (Low Frequency Effect) output. Unfortunately, this sub doesn't have a line-level (speaker wire) input. Sorry.
INNOVAGE JUMBO REMOTE CONTROL
Try pressing the channel up button multiple times to see if you can help the remote find the code. If you push the channel up button enough times and "something happens" then immediately press the mute button to save the code. It worked for my Sylvania tele.
Sc-ht500 system cable
You cannot wire this system separately, since it is very difficult to separate the power cables from the others which carry the audio parts.if in any case , lets suppose, you could wire the dvd player separetely, you will have no audio since all the audio frequencies are transfered in this cable to the sub woofer and from there to the satellite speakers.
It would be useless to wire it even if we could as there would never be any audio, only video, no matter what disc you use as the only way the audio is comming is throught this system cable to the subwoofer. Actually its the worst idea to implement in a home cinema system, but well, this is old panasonic.. :)
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
