HP Support Communityhttps://h30434.www3.hp.com > td-p
Jul 14, 2017 - I have the same issue. Almost new machine. Screen says "clear carriage jam", but there's no paper jammed in there. Can't do anything with the printer, since ...
The
Carriage Jam
error message displays on the control panel display. The print
carriage, which holds the ink cartridges, stalls against the left side
of the printer. A paper jam might have occurred previously.
HP Printer Error 0X610000F6 also known as Carriage Jam Error occurs very often in the Photosmart HP Printers. When a jam occurs in the printer due to paper scraps or due to any other reason, the printer stops working and it doesn't print any document.
If you already followed these instructions, the last thing to do is to service the printer. I don't know of any self-fix options for this printer. It's worth validating that you've already completed these steps as described.
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Complete
the steps below in the order presented to resolve the problem. It might not be
necessary to complete all of the steps. Step
one: Reset the printer
Without turning the power off, remove the power cord
from the back of the printer and from the wall socket.
Wait 30 seconds and reconnect the power cord to the
printer and to the wall socket. Turn the unit on if it is not already
turned on.
Check the printer for the error message. If the error
message still displays, go to the next step.
Step
two: Clean the cartridge contacts Figure
1: Lifting the top cover Lift the top cover.
Locate the ink cartridge indicated in the error message.
Squeeze the gray tab below the cartridge slot to release the latch, then
lift the latch.
Figure
2: Unlatching cartridge
1 -
Black cartridge 2 -
Color cartridges
Remove the cartridge indicated in the error message.
Go to kodak.com/go/itg and follow the step by step troubleshooting. If you still get the same error,Time to contact Kodak at 1800 421 6699 and Your printer will be replaced free of cost.
Usually when the printer displays a carriage jam error the carriage assembly is jamming along the carrige path.
There may be something in the carriage path or the carriage shaft may need lubricating.
Check the area where the carriage is has stoped. There might be an obstruction visible.
Get Instant services and solution for your HP Printer support. Printer services USA is here to fix your printer anywhere anytime, just call us on our toll-free printer number +1 866-918-4391 or for more visit our official website
https://www.printsupportusa.com/
