Kenmore Elite 45986 Front Load Washer Logo
Posted on Jul 04, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
F2 error code on my Kenmore Elite HE3 washer
I keep getting an error code that flashes F then 2. I have been pausing the cycle and then pushing the start button and the load will finish with 22 minutes left in the cycle. Last night the machine would not drain and every time I would try to start it the code would come backe up. I tried th drain and spin cylce, but the machine only filled with more water and the error code came up again. Any suggestions? I have a Kenmore Elite HE3 front load washer model # .44836300. Thanks
  • 11 more comments
  • lealm Jul 04, 2008
    Thank You! We just finished cleaning out the filter. It was very clogged up. Everything went just as you explained. Even the amount of water!! I haven't had a chance to run a load yet, but I am sure that it will work great. Thanks again for your help.
  • Anonymous Aug 29, 2008
    My machine won't spin or drain and we will be checking the pump filter to see if it is clogged.
  • Anonymous Aug 31, 2008
    That was it! It's drains now. I don't understand why Kenmore will not explain this simple fix over the phone? I told them the error code, but all they said was "Do you want an extended warranty?" and it will be $68 for a service call. We had them scheduled to arrive, but now we are going to cancel the call. Thanks for your help.
  • diegerMR Sep 01, 2008
    I am having the same F2 problem, but where is the filter?
  • smr10 Sep 02, 2008
    We located the drain and drained the water-you were right, the water went everywhere-we just now finished mopping up. We did not find any debris in the filter-I guess that means the pump is bad ??? I hate to try again and have to mop again!!!
    Sara
  • Anonymous Sep 09, 2008
    Having the SAME EXACT PROBLEM... I get a flashing around 11 minutes left of F then 02 of a flash... I am thinking maybe the filter will have to get my boyfriend to look at it but will following the direction that everyone gave... thanks for the comments going to try it.
  • Anonymous Jan 04, 2009
    I had the F-2 error also... I glad I checked this site, cause my problem appears solved.. Pulled the lower panel, unscrewed the cap, and low and behold..... Coins, pencils, more coins, and other items that were left in pants pockets... Saved me $$$ for a service call, or even a new unit...!!
  • gala36 Jan 28, 2009
    In the middle of the cylce I get FO2 error, on Kenmore Elite HE3, but I don't know where the filter is to clean it out
  • Anonymous Mar 14, 2014
    spin to the 10 minutes and then goes back to 12 minute and starts the process again
  • Anonymous Mar 25, 2014
    After 8 minutes, FH error code comes on.Water is filling the tub.
    Checked Drain Pump.
  • Anonymous Mar 28, 2014
    washer sensing light comes on but won't do anything. repairman said it needs two boards but when I was taking washer out and water from drain wet the floor, I found the power outlet wasn't getting power since my wetvac wouldn't run from that same outlet. I am doubting the repairman's diagnosis at this point. Tried Rockwell's door latch test but can't get further than pushing prewash button 4 times; I get a 002 code displayed. What next?
  • Anonymous Mar 31, 2014
    Does not drain,washer just stops
Anonymous
Level 3:
  • Master 413 Answers
  • Posted on Jul 04, 2008
Anonymous
Master
Level 3:
Answers
413
Questions
0
Helped
209693
Points
1203
Based upon your description, the drain pump has either failed or the pump filter has become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) BE READY TO CATCH LOTS OF WATER. CAREFULLY AND S_L_O_W_L_Y unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.
If you need further assistance, let me know
Regards,
reg501
  • 4 more comments
  • Kenneden Feb 02, 2011
    This literally took about 5 minutes to complete from start to finish and completely fixed the washer. I had 3 socks and a wire blocking my filter. There was very little water spillage but we had the shop vac and towels handy just in case. This is very easy to do!!
  • kambo830 Apr 26, 2011
    Awesome advice!!! Done in ten minutes and back in the laundry business. I thought it may be the end of my machine but thanks to you she still has some time left and work to do!
  • Calfan87 Jun 12, 2011
    Really appreciate the easy to follow advice. I was amazed at the amount of gunk blocking the drain. Good as new now. Just one thing to add - mine needed a torx screw driver to remove the lower front panel. Thanks for you post.
  • Anonymous Oct 09, 2012
    No matter who you are, if you read this, and you have this washer, check your clean out anyway. We found two sockss and more! No wonder it was slow and stunk. You can do this in less than 15 minutes.
  • Anonymous Jul 09, 2013
    this was awesome! worked like a charm... got 1.50 in change, gunk, hair elastics and a few legos! thank you, thank you !
  • Reza Hassan
    Reza Hassan Sep 11, 2013
    Thank you, thank you, thank you. Amazingly easy thing to do. Found kids sock, quarter, toothpick, etc.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 15, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
16340
Points
8
If when you are "S_L_O_W_L_Y" unscrewing the pump clean out you will have a shop vac turned on and at the bottom of the cap you are unscrewing, it will **** up all the water draining out with little to no mess. I just tried the technique above after having the same problem and trying the fix above, (which worked by the way...2 infant socks, .15, and a bra underwire later all the slug was removed and we were back on track). I didn't have any water to clean up at all and my shop vac was half full of water! By the way, I used the shop vac to **** out the drain hose that leads up to the outside drain hose since I couldn't reach up in the inside of the washer far enough to remove it. I sucked a bunch of stuff out of it too that had made it's way up there and cleared it; otherwise, I would've still been stopped up.
  • Anonymous Jan 07, 2013
    this is awsome did what you said with the shop vac< and lordy lordy i found a sock and nails and pennies, wow it was so clogged, im so happy i dont hve to call sears to repair it, thanks so helpful
    thank you, thank you, used the shop vac,great! found a sock in the filter and nails< wow so clogged flushed everyyhing out, now working great
Anonymous
Level 1:
  • Posted on Dec 12, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
16340
Points
Power of internet, was ready to look for a new washer until I came across this fix, followed suggestion and found 2 facial towels wrapped within pump filter, removed and put everything back together and washer seems to be working like a gem, thank you for the great advice.
Anonymous
Level 1:
  • Posted on Aug 15, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
16340
Points
6
Can I just say thank you? I followed your suggestion and it was a relatively easy fix that has been driving me nuts! Maybe now I'll finally catch up on laundry!
Anonymous
Level 1:
New Friend:
  • Posted on Jun 01, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
16340
Points
Same F02 and SUD codes. Read the posts. Tried it...worked like a charm. Thank you!!
Anonymous
Level 1:
New Friend:
  • Posted on Jun 22, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
16340
Points
One big tremendous THANK YOU for this site, and for posting the suggestions to resolve the F2 error on my Kenmore Elite He3t washer.
I followed the suggestion to remove the back panel, detach the rubber drain tube running from the tub to the drain pump and check for 'debris' . I found two of the purex 3-in-1 laundry sheets I saw at the store and decided to try out. Removed them (with no water spilled I might add) and problem solved!
I've done 4 loads of laundry with no errors. Thank you for the extremely helpful troubleshooting tip and remember, stay AWAY from the all-in-one laundry sheets.
Anonymous
Level 1:
New Friend:
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
16340
Points
Hi (easy steps): 1)use a hose to drain the watter from the washer to a bucket. 2)use a shop vacuum to drain the remaining watter; plug it to the draining hose. 3)take three -7mm- screws form the front lower part of the washer. 4) pull down the cover with your hands -no tools needed for that-. 5)turn the drain plug -this is also the filter- and pull it off. 6)us your shop vacuum to clean the inside and every little hole there. also put it in the draining hose again -this will help to clean the pump and the hose. -YOU ARE DONE. put it together and behold problem solved- =)
Anonymous
Level 1:
  • Posted on Oct 25, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
16340
Points
Same problem.. F2 error, nothing works, tub locked and full of water. Removed bottom panel, Had shop vac and old towels ready and unscrewed 4" drain plug. Filled the shop vac and towels with smelly water and removed sock from pump along with some coins and beads. I also used the shop vac **** out the pump to be sure I got everything. Washer is now working properly again thanks to this website.
Anonymous
Level 1:
  • Posted on Jan 04, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
16340
Points
Glad I checked this site too!!! Pulled the pump filter cap, and low and behold.... Coins, pencils, more coins, and other pant pocket items... Saved Me $$$... Thanks....
Anonymous
Level 1:
New Friend:
  • Posted on Jun 02, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
16340
Points
Just wanted to say thanks!!! Like everyone else I found a small nylon sock in the front of drain hose just outside the pump. This was an easy solution and alot cheaper than a new washer!! I love this site and I'll be back. Thanks Again
Anonymous
Level 1:
New Friend:
  • Posted on Jun 01, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
16340
Points
I am sooo thankful I went on this site! I has having the F02 error and I unscrewed the bottom panel to get to the drain pump there were 7 coins in there along with a necklace! took everything out and the washer is working fine now.........now all I have to do is clean up all this water lol
  • cpabgl Jan 01, 2011
    Ditto Here.... Followed the suggestions and sucked out a baby sock! Works great!!! Thank you very much.
  • chorizon Mar 11, 2011
    I had the same F02 error code and followed the above directions and, yup, I found two of my teenage daughters socks stuck in the filter along with a couple of coins and a lot of muck. So far so good, no more error code. Thank you so much reg501, you're the bomb my friend. You saved me a lot of money that I really can't afford to spend right now. God Bless!
    Esau in California
2 Related Answers
Anonymous
  • Posted on Jan 11, 2009
SOURCE: F2 error code on my Kenmore Elite HE3 washer
Had this problem on our Kenmore machine.
This is what done.
1. Unplug the washer
2. Take of the toe panel in the front by removing the three screws.
3. Get a bunch of towels (I mean a bunch!!!)
4. The pump is in the center, and it has a plastic grip handle that one can unscrew to remove the filter. As you unscrew it, LOTS of water will come out. Be ready with the towels. A cookie sheet helps to collect the water too.
5. Clean the filter assembly.
6. If one wishes to check the inlet of the pump, remove the back panel, about 12 screws. (Note, the following works for replace the pump as well)
7. Remove the large bellow from the bottom of the tub that goets to inlet of the pump by removing the clamp
9. Lift up on the plastic cover that covers the wires that power the pump. There may be a small plastic catch that is lifted up as to allow the connector to become free.
8. Remove the Torx screw that holds that is the center just under the filter screen.
9. Pull the pump forward.
10. Unclamp the pump outlet hose.
11. Remove pump
12. Unclamp the large bellow on the pumps inlet and inspect for debris.
13. Clean pump and fitler w/o getting water on the pump.
14. Install in reverse order. Remember, it is much easire to put the inlet bellow and outlet hose on the pump before you put into the washer
Anonymous
  • Posted on May 13, 2009
Depending on how fritzed your drain pump is this may or may not work. I've been using HE detergent because it is supposed to cause fewer suds. However, apparently is causing more suds than needed. I need to use only a couple tablespoons? If your clothes are not dirty enough for the soap to grab onto then extra suds are the result. The repair guy said we had an excessive amount of suds in the system and this affects the sensor and causes the drain pump to run and run and run until it shuts off from overheating. This is why we get the F2 and/or suds error code. He said once a month run the machine on the hottest water cycle with a cup of bleach (no clothes). This will clear out any suds build-up and is cheaper than Afresh which works, too, (but smells cleaner than bleach). After sitting for a day our pump started working again (yay!) It also stopped making the horrible loud sound. So glad I do not have to replace the pump!! yet...(knock on wood!).
How to run diagnostic on Kenmore elite smartwash quiet pak 9 HE4t washer? Model#110.45087401
Diagnostic mode for Kenmore Elite He3t model 110 42926 ...
iFixit https://www.ifixit.com > Answers > View > Diagnostic...
Apr 8, 2016 - With the washer empty, close the door. · Push "control/on" or "Start" · Select "Drain/Spin" · Select "No Spin" by pressing SPIN SPEED touchpad.
3 answers · 2 votes: I believe this is very similar to the model I have. Here is what I did to run a diagnostic. ...
F11 error code during Diagnostic test? - Kenmore ...
1 answer
Jan 18, 2016
SOLVED: F11 code error on Kenmore HE3 - iFixit
Mar 3, 2011
SOLVED: f h error code - Kenmore Elite HE3 ...
Feb 21, 2012
It seems like the washer has no power - Kenmore Elite ...
Nov 2, 2017
More results from www.ifixit.com
Diagnostic Test; Starting The Test Mode; Test Program ...
ManualsLib https://www.manualslib.com > ... > User manual
Close the door. Select the DRAIN/SPIN cycle. Select NO SPIN by pressing the SPIN SELECT button five (5) times. Push Prewash Option button four (4)times within ...
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Kenmore elite h3 front load washer is not working error code f2 flashes
The F2 error code mean that the washer didn't drain the water within the normal time it takes to drain,usually the reson the washer hasn't drained properly is because the filter screen on the drain pump is clogged with debris. this tip i have written will show ya how to clean the filter on the pump.
http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
GENE
Whirlpool washer duet is flashing after adding garmet. Will not return to washing
April 8 2002 DIV 26 SOURCE 110 KENMORE ELITE HE3 & HET WASHERS "ADD-A-GARMENT" INDICATOR LIGHT ON DOOR WON'T UNLOCK WHEN PAUSE/CANCEL BUTTON IS DEPRESSED.
MODELS: See additional page for Kenmore model numbers
COMPLAINT: Due to a Microcomputer Machine Control software error , the ADD-A-GARMENT feature becomes inoperative.
CORRECTION: The Microcomputer Machine Control must be replaced with a service part that has been reprogrammed to prevent ADD-A-GARMENT feature loss.
PARTS: Order electronic control listed on this service flash by model from Division 26 , Source 110 following normal ordering procedure.
MERCHANDISE CODES: WASHER Service Flash - Model Nurnbers for: Kenmore Elite HE3 & HE3t Washers: "ADD-A-GARMENT" indicator light on door won't unlock when Pause/Cancel button is depressed. Kenmore models with serial Numbers beginning with CSL23 through CSM04 11042822200 11042824200 11042826200 11042832200 11042834200 11042836200 11042922200 11042924200 11042926200 11042932200 11042934200 11042936200 Electronic conrrol p/n 8181900 Electronic control p/n 8181899
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
1helpful
Kenmore h2 error code
7helpful
3answers
Help! Mt Kenmore Elite Quietpak2 HE3 keeps
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
1helpful
*&^% screws!!!
F2 = Long Drain. Most common cause is something (or lots of things) stuck in the drain pump. There are screws at the bottom of the front panel that can be removed to check it out. If the screws look like stars they are Torx head screws, get driver from most home centers.
Go here for Kenmore HE3 washer parts:
http://www.repairclinic.com/Kenmore-Washing-Machine-Parts
www.RepairClinic.com
17helpful
Kenmore Elite He3t front load washer - error code reads H & F
the F code is a puwer outige. This is how to fix
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
This is what an HF code is.
"FH" (Water Inlet Problem--no water or insufficient water
supply)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer clogged?
Are water inlet hoses kinked?
Are water inlet hoses frozen?
Plug in washer or reconnect power. Re-select cycle and press
START. If the problem remains, call for service.
Alexander
vince
