If the system will not power on, I would suggest a new power supply as the first troubleshooting option as they are about 1/3 the price of the motherboard. The Flea Power indication on the motherboard only indicates power is reaching the board, not if all needed voltages are being received.
Normally on a Dell, if you are getting power then when you attempt to power on, you usually get a power LED indication on the power button. Solid Green/Blue is normal, Flashing Amber is Power supply bus failure, Solid Amber is normally a motherboard.
If you haven't bypassed the UPS and connected direct to the outlet, I would try that 1st, as the UPS could be the failure too.
