Hello *Tip: The iO button will light on for 20 seconds. The next step must be entered while the iO button is STEP2 Press the [INFO] button. The iO button will blink number of times indicating the number of each digit of the code number. Each digit is separated by a 1 second interval of the iO button being turned off. Example :One blink, three blinks and eight blinks with an interval of 1 second of iO button being turned off, indicates the code number 138. Note :Ten blinks is equal to the number 0. D. Program the Volume Controls. By following the steps below, the user can program the volume controls (Volume UP, Volume Down and MUTE) . The default volume control settings on the remote control is TV volume control. If you wish you can control the volume via your CABLE box, use the following steps. STEP1 Press the [CBL] button and the [SEL] button simultaneously for 3 seconds. The iO button will turn on. *Tip : The iO button will light on for 20 seconds. The next step must be entered while the iO button is on. STEP2 Press the [VOL +] button. STEP3 Press the [CBL] button. The iO button will blink twice to confirm the programming. To return to original state: If you wish you can control the volume via your TV,
Codes for Curtis TV with Cablevison remote control are:-
070 004 101 127 236 011 072 081 120 164
on.
repeat the above steps by pressing [TV] in STEP3 .
OK.
