Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
Tom Cope Posted on Mar 21, 2017
Frigidaire FLSE60RGS0 Transmission Replacement This is my son's machine. It fills okay, agitates okay, drains okay, but will not spin. Motor turns, but belt slips on motor pulley, and trans does not spin. Assume that transmission is bad, and needs replacing. Have a good bit of mechanical experience on industrial equipment (motors, pumps, gearboxes, and much more) but have never broke into one of these before. Looks fairly simple, but usually when it does, there is one trick that you need to know before you start. So, first off, is there anywhere you can get a maintenance manual to help? If not, what can anyone do to give that help? Secondly, how hard on a scale of one to ten is this to do? And lastly are there any special tools necessary to do this job?
5 Related Answers
Anonymous
  • 57 Answers
  • Posted on Feb 16, 2008
SOURCE: Frigidaire front load washing machine won't stop filling
it sounds like your water valve is bad or you pressure switch is bad or hose from pressure switch to tub is cloged
Terry Schneider
  • 177 Answers
  • Posted on Jul 03, 2008
SOURCE: won't spin to drain clothes still wet when finished
You may have a control board issue. I would recommend calling in someone to look at it.
Price out replacement vs repair it maybe time for a new machine.
T
Anonymous
  • 71 Answers
  • Posted on Sep 29, 2008
SOURCE: Washer will not spin
My mum had this problem. I think it had something to do with the barrel coming loose.. - get a plummer ;)
Anonymous
  • 2920 Answers
  • Posted on Feb 07, 2009
SOURCE: Washer wont spin or drain
did you check to see if there was anything stuck in the pump? sometimes socks and other small articles get dow there and wont allow the washer to spin or drain
BIKER T
Terence Fourie
  • 909 Answers
  • Posted on Oct 05, 2009
SOURCE: our frigidaire front load washer doesn't spin or agitate
Not quite sure what your question is. Let me know.
1helpful
Frigidaire Washer Dryer Combo FEX831FS2 will fill, does not agitate, does not drain, but does enter the spin cycle/
Question edited for clarity 'make model (what it is).
Question moved to Frigidaire Washing Machine.
This is the Transmission unit, which I would say puts it beyond economical repair.
Frigidaire H Transmission #WCI-134735700
List Price: $765.13
Sale Price: $637.61
On first reading, I thought it sounded like the pump, but then no agitation, but it spins. This makes it sound like the control board. In view of the confusing actions and the cost involved, I would call out a Service Engineer.
https://www.partswarehouse.com/Frigidaire-FEX831FS2-Washer-Dryer-Combo-s/70205.htm
1helpful
Will not Agitate (Frigidaire GLWS1233AS1) The washer fills and then stops. If I manually change the timer to the end of the cycle it drains and can spin. I saw on older posts that this might be a...
When ya say after filling "the washer stops" does that mean it is not making any sorta sound?? if it is the transmission,agitator block,or evena stripped gear you will hear the motor running yet it will not agaitate and from reading your question i think it says their is no sounds yet instead it fills then just sits their silent,is that so??
If yes their is no sounds it could be in the area of the timer where the problem lies, since it will drain/spin i am exluding the motor, lid switch or belt as the problem.
If it does make sounds yet just wont agitate it could be a stripped agitator block, or stripped gear but,the belt would be ok since it spins
GENE
1helpful
Replaced the belt and still not agitating, switch seems good
If the machine fills, won't agitate, wont drain or spin, then you need to replace the lid switch.
if machines fills, wont agitate, will drain but not spin, then you need to replace the motor coupling
Washer fills, agitates and drains but will not spin (any speed or cycle).
  • Test the lid switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the agitator
  • Inspect the pump coupling
  • Test the water level switch
These are the common problems of a washer that will not spin. In my opinion I would say check the transmission. Any more questions feel free to ask.
2helpful
My Frigidaire Gallery Model #GLWS1339CS1 will not agitate. It fills, drains and spins okay and at the proper time. When the machine hits the agitation cycle, I can see the agitator engage, but it doesn't...
It doesn't agitate
If your washer doesn't agitate, check these:
Lid switch
If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler
Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts
Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch
If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor
Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys
The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission
The transmission could have either of these problems:
Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator
The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
My washer wont spin
Your symptoms that indicates a broken motor coupler. If your washer will drain and fill but has not agitation action or spinning action that would indicate a broken motor coupler. The motor coupler links the drive motor to the transmission.
1helpful
Won't agitate or spin
Probably the motor coupling has cracked. Located between the motor and transmission/gearbox.
Washer won't agitate or spin
The transmission is dead!
It's not worth fixing!
If it's 10 years old or more, better off replacing it with a newer machine which will be much more efficient!
1998????????????
Not worth the money to fix!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Try You should call service.:
A&E Factory Service
1-800-905-9505
Nation wide / 7days/24 hours
Good work
Please give me a "Solution Solved Rating", in this site!
Thank You
Neil
4helpful
2answers
Washer does not agitate
hi thanks for the question it looks like a problem with the transmission but only if afer the water fills the tub the motor starts running if te motor docent start after its full look for a timer problem . so if motor runs on wash cycle and no spin transmission problem thanks the appliance doc please rate me.
2helpful
2answers
Washer repair
The transmission might have locked up causing the motor to overheat.
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
